Lakewood 2096 et manualou
Where do you put in the oil? or do you have to put in oil for a Lakewood 2096ET? Please e-mail me at Sportslettering@gmail.com - thank you - just needing to know where you put the oil in at - have looked all over it and can't figure out - Thank you
    Top Expert:
  • Heating & Co... Master
  • 33,330 Answers
There may be no provision for adding oil (?). Most oil-filled radiators are filled and sealed at the factory.
Posted on Nov 21, 2013
SOURCE: Lakewood 7096
i went all over town looking for a switch. finally found two lighted switches at grainger carling technology part no. 1A824. ground down the outsides glued both together jumped across top and bottom terminal with copper wire and it seems to work fine now.only time will tell. i hate our throw away society which the junk imported in from china seems to foster.
Posted on Oct 08, 2009
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
SOURCE: The Lakewood 5500 oil-filled heater has stopped
Similar problem here. But in my case, it was a blown fuse. There's an in-line fuse on the internal wiring of the heater. Take the control-side off (remove the bottom grey plastic bracket, then remove a sheet metal screw, then slide the whole assembly down off of the radiator). Where the elements go into the reservoir at the bottom of the radiator, the white wire should have an inline fuse connected to it. It will probably be covered with what looks like heat-shrink tubing. Snip, snip, and replace.
Posted on Jan 11, 2010
  • 3 Answers
SOURCE: Need a thermal cutoff for our Lakewood 5500
We have these heaters and haven't had a fuse fail yet. I think it's because after the first time I got that crackling sound after moving it while it was on, I stopped doing that, and only move it with the power off, and wait two minutes before restarting it, so the oil can resettle.
However, the thermostats are now failing. Anyone know if this part is available?
Posted on May 14, 2010
  • 123 Answers
SOURCE: Where can I buy a
Here you go... http://www.1sourcecomponents.com/partinfo/DRH-2415.htm
Hope this helps. Please leave feedback!
Posted on Jan 28, 2011
My heater model 7096, The 2 wheels are broken, Can I buy new one to have them replaced?
Not from lakewood. they went out of business. I suggest a harware store ot E-bay for a used unit.
Mar 30, 2011 | Lakewood Oil-Filled Electric Radiator...
I need a wiring diagram for a lakewood 5500
Visit this page for service center info and or parts: they should be able to help you http://www.lakewoodeng.com/html/parts.html
Feb 13, 2009 | Lakewood Oil-Filled Electric Radiator...
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
