Question about Singer Confidence 7469 Mechanical Sewing Machine
Bunching up and seizing at bobbin - Singer Confidence 7469 Mechanical Sewing Machine
    New Friend:
    Problem Solver:
  • 11 Answers
You meant the thread? I just had the same problem. it was my bobbin was slightly bent due to constant use or factory defect. I replaced it with a new one and now works great!
Posted on Nov 21, 2013
The bobbin thread is bunching up
hi Lois.
this is all i could find out.
Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turn.
or try this link.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
or this one,
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little window might open up in the middle of the page just close the little window down.
or this.
The bobbin thread is bunching up Google Search
Dec 12, 2017 | Sewing Machines
My Janome 8050 bobbin case is jumping out of place. The thread is wrapping around the bobbin case and getting stuck, bunching up, and shutting down my sewing progress. It ties the needle up.
check for the retainer action of the bobbin case to see in there is a part broken off that holds the bobbin in the case or carrier
from what you describe , with the thread bunching up etc, I suspect that the needle thread tension is too loose and causing the problems
if so then the bunching and problems can be from the bunched thread pushing the bobbin out of position
take it in for a service and if necessary , repair
Dec 20, 2016 | Janome Sewing Machines
Thread bunches up into a knotted mess on bottom. Bobbin doesn't sit flat inside the bobbin case but spins with a tilt, lower on the left and higher on the right. Bobbin touches plastic cover plate.
Usually, thread bunching under the fabric is an upper tension issue. Be sure to ALWAYS RAISE the presser foot when threading the upper thread.
With the bobbin case operating at a tilt, there is something mechanically wrong with the machine. It may be best to take it for service.
Aug 30, 2016 | Singer 4411 Heavy Duty Sewing Machine
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Thread bunches up when replacing thread on bobbin
If the thread is bunching or tangling when winding a bobbin, check that you have properly threaded the winder. Especially make sure you are running the thread through the bobbin tension assembly.
Aug 21, 2014 | Singer 5050 Mechanical Sewing Machine
Bobbin bunching on elna 3230
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin case is inserted correctly in the machine
it's also possible that the bobbin case needs to be replaced
also check the bobbin it could be warped
it's also possible that the timing needs to be checked on the
machine
Nov 22, 2012 | Sewing Machines
Thread bunching and bobbin winder quit
This sounds a lot like you've forgotten to lower the presser foot. (this leaves the tension discs open and causes serious issues below the material.) Double check that and if still having issues post again.
Nov 03, 2012 | Brother SE-270D Computerized Sewing...
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
Hi...i have been having trouble with my bobbin thread bunching up really bad underneath and causing the machine to seize up when i try to sew...it starts to do this just after a few stitches...i make sure...
Always remember that it is the opposite of what you think, it is your upper thread that is not threaded right, not your bobbin. Once you thread it right, you should be okay. You can buy a manual at sew4less.com for about $14.95
Jul 22, 2010 | Euro-Pro Sewing Machines
Bottom thread bunching
Oil behinde the bobbin holder so that bobbin holder can run smooth in the bobbin casing. wcbotha@yahoo.com
May 11, 2010 | New Home HF-2022
Singer Confidence 7469 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
