Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet My washer does not drain all the water out of the drum can you tell me why.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Remove the bottom kick panel and clean the filter out.
Posted on Nov 21, 2013
4 Suggested Answers
  • 107 Answers
SOURCE: My Whirlpool duet washer is not draining. I am
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
Posted on Mar 20, 2009
SOURCE: Whirlpool Duet Washer Leaking
For those wondering about replacing the water inlet valve - this is a very simple undertaking.  You can find the part online for around 40 bucks.  All you have to do is unplug the washer, detach the hot and cold supply hoses, remove the lid (3 torx bits on my model) unhook the water line from the old inlet valve (conveniently accessible at the top right of the unit from the rear), unhook the electrical connections (be sure to label these for later re-attachment), unscrew the 1 screw holding the valve in place, and reverse the process with the new valve.  I'm hoping this will stop water accumulating in the drum - I'll update later if it does not.
Posted on Apr 11, 2009
scottludwig3
  • 4 Answers
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
Posted on Nov 17, 2009
I just bought a new washing machine and I am waiting on delivery. Can you tell me if the new machine comes with a drain hose?
The washer should come already equipped with the drain hose and color coded fill hoses (RED stripe for HOT water, BLUE stripe for COLD water. The water tap hookups are also embossed on the back of the washer, to ensure you don't cross the hoses. It will also have shipping bolts installed that stabilze the drum for delivery. If you're having it delivered, make sure the technicians remove the shipping bolts prior to using the washer.
Dec 01, 2010 | Kenmore HE2 Plus Front Load Washer
Duet GHW9150P Front Load Washer: I find water in the drum after i have washed cloth...
Check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer leaves water remaining in drum after the entire wash cycle, it becomes stale and makes my clothes that I was smell. My father's front loader, GE, does not leave any water in the drum
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
May 13, 2010 | Samsung WF203ANW Front Load Washer
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have an LG front loader. It washes fine, drum is clean ... no smells in the drum. After each load, I have a huge bowl of water that I have to get out of the little black hose (left side bottom). It...
There will normally be a few cups of water left in the hose although it should not smell very bad though as this water from the last rinse and should be fairly clean. If the drain is connected to the drain under a sink make sure the hose goes up as far as possible then down to the washer.
Apr 19, 2010 | LG WM-2277HW Front Load Washer
Drum is full of water
There should be no water left in the drum once the wash is completely done.This is probably a drain problem. Doing the following checks might help->
Inspect the drain hose for kinks
Inspect the water pump
Inspect the drain pipe and hose for blockages.
Please do rate my solution if it works out.Also do post further comments if any help needed.Good luck with the machine.
Apr 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Ge washer not draining or spinning
HI yes you can remove the pump and clean. the pump is the problem
Oct 12, 2008 | GE WBSR3140DW Top Load Washer
Leaking valve
can be either hot or cold valve - only way to tell is to turn off hot and cold water in turn. however, a common cause of water accumulating in drum is if drain is connected to sink spigot, then when you empty sink, some of the water goes into the machine. cure is to take drain hose up as far as possible in a swan neck
Aug 20, 2008 | Kenmore 44102 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
