Question about Kitchen Ranges
Cgr3742cdc tech sheets
F1 error code
3 Suggested Answers
SOURCE: Bosch Tankless water heater. model AQ 250 SX
Error codes F1 and F2 do not show among common error codes.
Call Bosch 1-800-642-3111
Before calling service technician, open following links for Bosch troubleshoot resources:
Error codes are considered start-point for troubleshoot.
Multiple error codes can indicate PC board failure.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/Troubleshoot/tabid/569/Default.aspx
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/ServiceBulletins/tabid/573/Default.aspx
Posted on Aug 11, 2011
  • 5 Answers
SOURCE: f51 error code on wtw6700tw washer. Lost the tech
Was a far easier fix for me than all this RPS sensor hunting. For my machine's F51 error, there were socks lodged between the inner and outer tubs, causing too much friction on the motor. This led to the computer reading poor performance of the motor. Please consider trying this easy fix before calling out service personnel or replacing circuitry!!! I spent hours under the machine messing with the motor and circuitry until I looked up at the translucent tub and saw stray laundry stuck where it shouldn't be.
* Open the lid. Turn the bottom agitator by hand. Give it a good push. It should continue rolling on for several turns. If not, there is laundry stuck between the tubs causing friction.
1.) Pry open the metal case lid. Take two flat head screwdrivers and wedge them in the crack about 6 inches from the left corner, and use them as levers to pop the metal lid, then the right corner. Lift up the metal case lid and lean it against the wall.
2.) Take off the plastic ring that bridges the gap between the inner and outer tubs. There are many little catches all around the perimeter of the outer tub that hold on this plastic ring. Find those catches and put outward and upward pressure on those to release the catches.
3.) Look down in the gap between the inner and outer tubs for stray laundry. I used a retrieval tool, below, to grab the socks. There were especially several socks in the back right corner near the pump inlet. Run the drain and spin cycle and look again. There were more strays hiding that I nabbed the second time!
4.) Snap the inner cover on by lining up all those catches and seating them. Snap the big metal lid back on by aligning and giving a good downward thump. Run the machine and be the hero, and don't be too mean to your wife about tossing those socks down in the crevices. Half hour and $3 for the retrieval tool is far better than all that RPS nonsense.
Posted on May 20, 2013
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
I get F2:E0 F2:E1 and F2:E3 as well as the continuous beeping. Unplugging does not resolve the problem. I can turn on the oven, sometimes, but it goes off by itself. Sometime the controls don't work at...
Kitchen Aid Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line openfrom what this says you could have a bad touch pad,it says to press cancel,if the code comes back after a minute you have a bad touch pad.there's a tech sheet on you machine with all the codes on it,look behind the top console taped to the back.make sure you put this back,if someone comes in to work on your machine and that paper is gone it will be hard to work on it,all machines are different.
Apr 21, 2011 | KitchenAid KGST307 Gas Kitchen Range
My washer model number wtw6200sw0 keeps giving me an f1 error code. what do i do?
Primary Control Failure
F then 1 flashes when there is a primary control failure. Replace
the machine/motor control assembly. See Accessing &
Removing the Electronic Assemblies, page 14.
WTW6200SW0
Tech Sheet
Aug 10, 2010 | Whirlpool Washing Machines
665.95802000 f1 - E 1 error code
take the consol off you will find the tech sheet with all the codes. make sure you turn your power off first.
Dec 23, 2009 | Kenmore Ovens
Washing machine u/l all the time ?
whirlpool F1 code - Appliance Repair Forum i would call the factory because there is a recall on your washer,they're having problems with the control board,also in the console there is a tech sheet that has all the error codes on it,put it back,without that paper if you call someone out in the future they will need the tech sheet to find your problem
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error message on the clock. Oven will not work. I purchased a new clock and recieved the same error. What could be the problem? Could it be the heating element?
The meaning of the various error codes varies by manufacturer and model. If you replaced the clock/control board you may have found a tech sheet taped to the panel that you removed to get at it. Usually the tech sheet will explain the error messages. If not, email me at bruce@fixyourboard.com and I will attempt to find the info for you.
Oct 14, 2009 | Kitchen Ranges
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F 1-4 Error Code
f1 is usually bad oven control board. Look for a tech sheet on the back of the oven. This will tell what all of the codes mean and what to check for.
Sep 24, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Dead control panel
No F7 or E7 in my tech sheet could it be a F1 F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad let me know thanks
Jan 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
