Problem with xerox Doc Centre 470ST
I have a problem with this copier. When the machine is turned on, it fails to complete self check and gives the error 'COPIER NOT AVAILABLE. MAY NEED SERVICING.' i have replaced the xerographic module and the waste collector and still no improvement. i will appreciate any help on how to carry out the service. Thank you.
  • jyyu44 Oct 29, 2008
    The big problem is a dirty copy my machine is xerox 470 ST
    my Email is [email protected]
    i need your help
    Novelist:
  • 208 Answers
Most likely the donor roll in the developer housing is bad.
That machine has a long setup sequence, and when the roll in the developer is bad, it will not set up properly.
From what you are saying, that sounds like hhe problem.
Posted on Dec 05, 2007
    Problem Solver:
  • 17 Answers
Uwasbisi... It is not un-common for the Xerographic modules for these models to be defective right out of the box. I myself experience about a 50% DOA rate. You may want to try another one.
Before you do that though, try this...
Remove the xero-module and the toner cartridge. Look into the now empty compartment area's (you may need a flashlight), and directly above and center to the magnetic developer roll/housing (under where the toner cart was, and directly left of where the xero-mod was), there is a photo-sensor mounted to the toner/developer housing that faces the (now removed) xero-module. It is rectangular in shape. About 3/4" tall and 4" long. Clean it off with a dry lint-free rag thoroughly. Do not remove toner/developer from the face of the magnetic roller that faces the xero-module. Only clean this sensor above it.
This is the sensor that "reads" the toner density produced on the module during set-up, and if it's dirty (and it DOES get dirty considering it's location), it can cause the type of problem you are experiencing.
All that being said, there are many other issues that may be the culprit as well (from a bad stapler safety gate on a sorter, to power supply board problems). Are you getting any service/error codes (you should be) in conjunction with the service message? You can look under the "error history" under "machine status" to the right of the touch screen.
Let me know.
Posted on Oct 12, 2007
SOURCE:
Xerox 7435 machin error 041340 plz advice for solutions
I found a reference to this for you in a Xerox service forum from one of the forum admins, who said:".....try reseating the Transfer Unit and see if that will clear the code. If not please consider contacting your support centre for further assistance."
You can find the message in her forum complete with links on how to do the above at the link below. Good luck! --Mark
http://forum.support.xerox.com/t5/Hardware/6280-gives-error-041-340-MCU-VRAM-error/td-p/22376
6280 gives error 041 340 MCU VRAM error
Oct 25, 2016 | Xerox Workcentre 7435 Color Multifunction...
Xerox workcentre 5745 network controller boots to 75% then fails and the reboot message comes up.
Try the following:
1. Power down the device
2. AFTER it is COMPLETELY powered off (can take up to 2 minutes), unplug the power cord from the wall.
3. Wait 5 minutes with the machine unplugged.
4. AFTER 5 FULL minutes have expired, plug the machine back in and turn it back on.
If this fails to restore functionality please call for service.
Apr 03, 2014 | Xerox 5665 Copier
Sir 010-398 in my colour xerox machine model no 1632 plese give me solusation whats problem give me answer
010-398 Fuser Lock Failure RAP
Description
The Fuser Fan failed.
Power OFF/ON
Procedure
Turn on the power.
Visually check the rotation of the Fuser Fan
Feb 26, 2011 | Xerox DocuColor 1632 Laser Printer
My Xerox Document Centre 265ST just stopped working and a message: Copier is not available Printer Fault please call for assistance I cannot access tools or anything else.
turn it off completely unplug it. open up all doors and trays....turn it on with everything open if you still get the error you are going to have to call in a tech if it starts up . start closing things till you get to when that errror comes up then repost and ill look up an answer for you. i work for xerox
Dec 14, 2009 | Xerox Document Centre 265ST Printer
CANON 4050 XEROX MACHINE
my xerox machine canon 4050 shown an eroor(E020)...we cant able to take copier
Oct 16, 2008 | Canon NP 6050 Copier
134 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
