Question about Refrigerators
Ge profile pgss5pjx not cooling - Refrigerators
3 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile PSC25 won't cool past 45 degrees
With that model that is a sign that defrost is not happening on time or the beginning of the problem. Temperatures in fresh food compartment above 38 are not safe. Look into the back of the freezer compartment and let me know if you see a frost line buildup. If yes it would be a good idea to manually defrost the freezer so you can remove the rear panel and check the defrost heater and defrost thermostat. It's also important that with this model that the problem be resolved quickly. I can help you if you want. The defrost heater will be easy to see if burned out because it has a glass tube around the heating element. If you replace the defrost heater you should also change the defrost thermostat. Fan motors going bad on that refrigerator seem to always damage the control board and if the board is replaced the the fan motor should also. Let me know if you want me to help you, Thanks, Sea Breeze
Posted on Nov 15, 2009
  • 1891 Answers
SOURCE: GE refrigertor profile no cooling
may be the main pc control board . bery comon . or some timer the compressor relay's .. mm
Posted on Jul 04, 2010
GE Profile French door not cooling 70degrees
The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
in other words is there ice frozen all inside if so unplug and take a hair dryer and melt the ice thouroghly
GE Profile French door not cooling Google Search
Feb 04, 2018 | GE Refrigerators
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
    Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
    Items in refrig are freezing when they're not supposed to.
    thermostat has failed i'd say..its not turning off at the requested temp.
    Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
    Jul 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
    ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
    May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
    Freezer and refrigerator doesn't cool properly
    Sounds like a main control board bad . A model number would help .
    Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
    GE profile counter depth side by side stopped
    Is the compressor coming on at all? If not a capacitor may be bad .
    Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
    GE Profile refrig side by side Model GSS 20iEMCC, not cooling
    Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
    heatman101
    df
    Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
    Refrigerators Logo
    160 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
