Question about LG E2360VPN LCD display TFT WLED 23 widescreen 1920 x 1080 250 cdm2 10001 5000 TV
Lg flatron e2360v-pn light flash at bottom but not coming on
2 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: lg flatron plasma 42" mz-42pz14
Hi dahill44,
This kind of symptoms is an indication of out-of-regulation in the power supply board where the power cord is connected. Leaky/dried filter electrolytic capacitor in this section trigger the symptoms. It will dropped the normal working voltage and in the first stage of fault warm-up will make itself stable but the symptoms will get worst, times will come that the unit will not power up at all.
Leaky capacitor has a physical indication of fault like bulged/dome at the top or at the bottom side and can easily be identify. See sample picture of leaky electrolytic capacitor below.
Dried capacitor has no physical indication of fault, you must have a capacitor checker to determine its condition. If not available, you may replaced all electrolytic capacitor in the output of the power supply section, it will not cost you much because this is one of the cheapest parts on this board. You must replaced it with same capacitance and working voltage which is printed in its body itself. Upon installation of new capacitor, you must ensure that the polarity (negative/positive side) will be in its location before soldering to the board.
Let me know if your handy with electronics and I will guide you fixing it yourself.
I you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified technician to isolate the faulty capacitor.
Also, check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 30, 2011
My lg monitor has line on the bottom half
Depending on the age of the monitor, it most likely will be Capacitors that are leaking. I have repaired many different brands of monitors and have seen problems very similar to yours. 99% of the repairs I do are capacitor Issues. It's well worth replacing them IF the screen is still in very good shape as far as brightness and contrast. most repair kits usually cost between 12 and 20 dollars.
Hope this helps!
Dec 06, 2013 | LG Flatron W2340vg-pn Glossy Black 23" 5ms...
LG Monitor L194WT - Indicator Lights Flashing
hi n hello
tried restarting the computer ?
Jun 19, 2008 | Computers & Internet
One side darker that other
the cause is either the back light get busted or connectors get worn out. but since it is a brand new you can avail the warranty just send it back to the supplier for check up.
Mar 24, 2013 | LG IPS226V-PN Flatron Widescreen LCD...
I lost my 12 V 3A DC adapter for my LG Flatron E2360V-PN What kind is compatible
have you been tried to find at the shopjimmy.com or at the amazon.com?. you can replaced it with other adapter even not LG, the only need to considered is the same voltage and amper rating as will as the size of the output jack and polarity of the adapter you will replaced. which will fit and same polarity to your monitor .
Dec 11, 2012 | Computers & Internet
I would like a copy of the service/repair manual for my LG Flatron E2360V-PN computer monitor. I was trying to see if there was any way to rig it up to be wall mountable. if not, i'd still like to...
Hi Nick,
I've checked my collection of service manual but I haven't a copy yet of this model no. I have only a direct link where you can buy and download it, click here.
This model no. does not have a VESA mount on the back, it means that there's no wall mount bracket option. However, you may try to contact the links below to inquire if they have a universal wall mount bracket for non-VESA PC monitor.
www.wallbracket.co.uk
www.armormount.com
http://www.networktechinc.com/monitor-arm.html
Have a nice day!
Kind Regards,Jdvillanueva
Nov 20, 2011 | LG E2360VPN LCD display TFT WLED 23...
LG monitor not working.
More likely to have failed capacitors in the power supply section, that will be the first place to check. Please see the pictures here so you know what to look for inside, post back what you find so we can guide you further and it will help other people also.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Notes: I will assume you have already try it on another PC and it still does not work.
Apr 06, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Powering up problem with my lg flatron plazma tv
Those lights are a code. I don't know which TV you have, exactly. But the manual will tell you what the light code indicates and what to do about it.
Oct 16, 2017 | LG Flatron L1919S LCD Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
LG E2360VPN LCD display TFT WLED 23 widescreen 1920 x 1080 250 cdm2 10001 5000 TV Logo
216 people viewed this question
Computer Repairing
Computer Repairing
