Question about Evenflo Baby Gear
Embrace 4851917 Need to adjust shoulder harness
5 Suggested Answers
  • 5 Answers
SOURCE: Embrace 5 harness release button jammed
Your car seat has a 90 day warrenty on your carseat, don't know if that is up or not. But I would check out this website, u can get a free manual for your carseat, I would give them a call or something:) Sorry couldn't be of more assistance.
https://plweb.evenflo.com/replacement_parts.aspx
Posted on Nov 20, 2007
  • 5 Answers
SOURCE: I am trying to adjust the harness on the Evenflo
see if it is passed right under in the pocket you have in the back
Posted on Nov 15, 2009
  • 45 Answers
SOURCE: Can not adjust harness straps on evenflow embrace
Evenflo has a GREAT website section on using and installing their carseats. The manufacturer is the final authority on keeping your child safe in their seat: don't accept advice from anyone else!
http://www.evenflo.com/sme_carseats.aspx?id=321
You also ought to have your instruction manual for reference: order it for free, at this link:
Posted on Mar 25, 2010
Dorel UK
  • 1629 Answers
SOURCE: How do you adjust the height over shoulders of harness on britax asis car seat
We would recommend you contact Britax to ask them or speak to your local nursery retailer for advice.
Posted on Jun 02, 2012
Adjusting quinny buzz harness for a newborn
Hi
This is not feedback we've heard before! Remember there are two places to adjust the harness - underneath the shoulder harness pads and at the waist position. To adjust underneath shoulder harness pads you need to undo the popper from the harness, slide the pad down the length of the harness and adjustment point revealed to make harness smaller.
Jan 03, 2012 | Quinny Buzz Jogger
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Can not adjust harness straps on evenflow embrace car seat
Mar 24, 2010 | Evenflo Embrace
I have a turn a tot car seat and the straps that hold her into the seat are to long and i can't work out how to shorten them and i can't find instructions anywhere
I guess you have pulled the harness adjuster strap tight (between the legs on the front edge of the seat) and are still left with slack shoulder harness straps. It may mean you need to remove the seat and check the harness straps are going thru the shoulder slots in the seat, then they need to go up and over the the metal shoulder rod before going down to connect onto the metal spreader plate
Dec 13, 2009 | Baby Gear
I need to adjust the straps to my car seat to fit my growing baby. I have tried multiple times to thread it through the back, but it will not work! I have tried everything and it seems impossible. Is...
you need to turn the car seat over and on the very bottom there are two gold rectangle-shaped clips holding the straps. You can pop these out and feed them through the hole....not like other car seats where the straps unattach up at the shoulder end.
Nov 01, 2009 | Evenflo Embrace
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Nov 14, 2007 | Evenflo Embrace
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Jul 31, 2007 | Evenflo Embrace - Rainforest
Baby Gear Logo
35 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
