Corsair 10ajb48a01 how many tons is this unit
Model 10AJB48A01. What are the specs for the motor starting capacitor?
it is either a 45/3 370vac or a 60/5 370vac depending on the compressor that's in the unit. if the unit serial number starts with 6936 it is the 45/3 if it starts with 6937 it is the 60/5
Jul 24, 2015 | Weather King Heating & Cooling
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
Is model #TCGD60S41S3A a 5 ton unit?
Yes. The number immediately following the "TCGD" advises one what the tonnage is. Your Model indicates a "60." So, divide the number by 12.
If the number is 60, it indicates a 5 ton unit
If the number is 54, it indicates a 4.5 ton unit
If the number is 48, it indicates a 4 ton unit
If the number is 42, it indicates a 3.5 ton unit
If the number is 36, it indicates a 3 ton unit
If the number is 30, it indicates a 2.5 ton unit
If the number is 24, it indicates a 2 ton unit
If the number is 18, it indicates a 1.5 ton unit
If the number is 12, it indicates a 1 ton unit
Hope this helped you.
Aug 24, 2014 | Heating & Cooling
10ajb48a01
One year labor and 5 on the compressor only. and it is 14 years old right?
Aug 21, 2014 | Heating & Cooling
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
I have an oddball question. What does a 3-ton A/C unit weigh? I know its not 3 tons.
Not every 3-ton unit weighs exactly the same - they differ in weight depending on how they were manufactured. Most 3-ton units weigh around 150 pounds (I would guess) give or take a few pounds.
The "3-ton" refers to the "cooling capacity" of the air conditioner.
It's actually 'slang' for 36,000 Btu.
Note; 12,000 btu equals 1 ton.
Hence a 24,000 Btu unit would be called a "2-ton unit," and a 12,000 Btu unit would be called a 1 ton unit.
Aug 05, 2011 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
WEATHERKING AC MODEL # 10AJB48A01
Many different problems there. Is unit humming? Make sure you have power comming in to your contactor on unit first. Ensure your calling for unit to come on. If those don't work let me know and we can go further..
May 23, 2008 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
