Question about Kenmore 15529 Built-in Dishwasher
Dishwasher I have a kenmore ultr-wash model #1560592/serial # fa0219349. It fills but the water won't spray.....help! thanks!
I found a plastic cone shapped part in the bottom and can not figure out where it goes. thanks
Posted on Jun 29, 2008
6ya staff
SOURCE:
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Model 655-15974990 won't wash or drain
What DOES it do? Just fill with water? Or doesn't it even do that? Do you have any lights on or flashing? Do you hear any noises when you try to run it?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
Kenmore top loading washing machine model 4021092, keeps filling
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
May 03, 2010 | Kenmore Washing Machines
Kenmore 1736 dishwasher fills with water but dosent spray
The pump motor is possibly out. I would contact an appliance parts house with the serial and model number to see the cost of the part before going any further. This motor is what pushes the water into the arms and does the wash and rinse cycles
Hope this helped
Dave
Feb 10, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Why do dishwashers have SO much longer run times today than those of the past? Our new Kenmore ''Ultr-Wash'' has extremely long run-times. How can that possibly be a good thing in terms of saving energy?
The latest models all pride themselves in doing a perfect job, almost silently, using much less water than the older models [thus the energy savings] as the most costly part of a dishwasher wash used to be the cost of the hot water. Your dishwasher only uses about 2 KwH of electricity compared to ten year old models that use 16.
Jan 30, 2010 | Dishwashers
My kenmore dishwasher model 587.1414 does not
Check spray arm for obstructions and if it is clear the motor impeller could be slipping or water system may need a good cleaning with CLR.
Eric
Jan 14, 2010 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore model 665 does not clean dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Aug 29, 2009 | Kenmore Dishwashers
Open Questions:
Kenmore 15529 Built-in Dishwasher Logo
174 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
