Question about Jelenko Jelblast Dental Lab Sandblaster
How to fix jelenko sandblaster - Jelenko Jelblast Dental Lab Sandblaster
Cleaning sandblast out of my 870 shotgun
scrub with wd-40 and a copper brush inside and out. then degease and refinish.
Sep 05, 2017 | Air Tools & Compressors
Sanblaster gravity feed bad media flow
Check that the new gun is compatable with the media you're using in your sandblaster. If you just replaced an old gun with the same kind you should be OK. Check that there aren't any peices of "stuff" in the line to the gun or where the line enters the sand. Next, make sure you are using dried air. Compressing air causes the water (humidity) to condense out and pool in the tank. This water then makes its way through your air lines and to your gun. If the air isn't dried by a filter somehwere on the line the moisture will mix with the sand and make it flow like you describe.
Jul 22, 2012 | RTO Gravity Feed Sandblaster
Maxus 125 lb. sandblaster gets clogged no matter what kind of material i use to blast and it makes no difference adjusting the valve
It's usually caused by moisture. It may help to dry your media in an oven, but the real culprit is probably moisture in your air. You need to add an air dryer to your line.
Jun 18, 2012 | Campbell Hausfeld Maxus 125 Lb Pressure...
Need to find manual for Dayton sandblaster model #6Z159 Nozzel #27-415 power-1000wt,vol.110-120,air volume 8-22 c.f.m,capacity 15-40lbs.
I have the manual you are requesting for the Dayton Portable Sandblaster Model 6Z159. Your info for the (Nozzel #27-415) is not listed. There are three choices for the (Nozzle..correct spelling) which are steel [pt# 497055]; ceramic [pt# 497020] and tungsten carbide [pt# 497010].
Sep 16, 2011 | Garden
My sandblast gun only outputs in spurts
Too much moisture in the air or wrong blasting media. Not enough pressure
Feb 13, 2010 | Air Tools & Compressors
My dauthers boy friend has a 93 buick skylark he just got his linc he put his car noise first in a ditch 3ft deep half full of water got it out found out he didnt have any brakes got it to start idles good...
More likley than not your plugs have to be changed, unless, they were cleaned with a spark plug sandblaster. The fouled out part of the plugs hides deep within the insulator chamber and cannot be cleaned without sandblasting. Therefore the spark, instead of tipping off at the electrode, tries to climb into the insulator chamber leaving a very weak spark. P.S. while changing the plugs, turn the engine over without them in to clear the cylinders. Thanks, Dana
Jan 18, 2010 | 1993 Buick Skylark
No Sand or Air is coming out when trigger is pulled
The sandblaster relies on a clear and unkinked line from the sand tank to '**** up' the sand and drive it out the nozzle with the air flow.
-Do you have air pressure at the nozzle? It may be obvious, but you need good air pressure. Pulling the trigger, you should get air out of the nozzle. If you don't, start with the air compressor.
-The sand needs to be dry and unclogged. Dump all the sand out of the container, and pour it back in through the filter screen.
Jul 29, 2009 | Campbell Hausfeld Maxus 45 Lb Pressure...
Compressor drops to 80 lbs when sandblasting, should hold 110lbs.
The air pressure on your system is actually controlled by the orifice size at the tip. The tip wears very fast and the air pressure will drop accordingly. Install a new tip and retest pressure. The only way to increase pressure as the tip wears is to increase the rpm of the motor/engine. Also check for leaks in the system. If possible, start out with a smaller tip and lower engine rpm a bit then increase rpm as the tip wears. You can also play with the grit size as the tip wears. Slightly larger grit/sand will work better as the tip size increases and pressure drops. Good luck with you sandblasting project.
Mar 31, 2009 | Air Tools & Compressors
Need to find where to get info on how to sandblast
make sure first of all you have a big enough compresor to run ur sand blaster always put clean sand in it,try using a screen if u have to reuse sand if big enough chunks get in the sand it will clog up.hold away from object to be sanded about 3 inches away from area to be sanded.always keep blaster moving if u keep it in 1 spot to long u can warp the metal.other then that i dont know specifically what u need to know.
Dec 22, 2008 | Air Tools & Compressors
Jelenko Jelblast Dental Lab Sandblaster Logo
44 people viewed this question
Top Jelenko Tools & Hardware - Others Experts
Are you a Jelenko Tool and Hardware - Other Expert? Answer questions, earn points and help others
