Question about AEG D5701-4 Electric Double Oven
Oven not switching on!
My oven was working perfecty last night. this morning no power, nothing. Everthing else in kitchen working fine. Is it possible to change a fuse, if so were is it???
2 Suggested Answers
  • 10 Answers
SOURCE: AEG Oven
try setting the clock, it may be automatic
Posted on Mar 22, 2008
"Amanda" ARDS802E. Why won't it heat?
Becky, it sounds like you have either a failed ERC or Electronic control board (Y0315030) or a bad limit control switch (31933003). If it's the ERC it's likely bad relay(s). If your clock is powering up and you see the clock then that lets us know that you are receiving power to the oven. If it's the Limit Control, then you will need to replace that approximately $60. It's inside the oven and prevents the elements from getting hot if it breaks. If it's the ERC then you can have it repaired for $99.99 from The Repair Shack. The link for the repair service is: Repair Service For GE Oven Range Control Board Y0315030. Hope this helps!
Nov 29, 2015 | Ovens
Hi Last night my oven just stopped working while I was baking. All the lights and clock went off and oven/broil controls are inoperable. The burners (and the electric ignition) continue to work fine. I...
You have a bad EOC electronic oven control unit, They are readily available from any parts house. They do not have instruction but are not difficult as it is just a few screws and swap out wire for wire. It may be a good idea to buy it from a vendor that allows returns of electrical items. Many do not allow returned electrical items. Please rate my answer and any comments are welcomed at least good ones:) Good Luck, Mastatech.
Aug 25, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
Used our Whirlpool AKZ451 last night and everything was fine, but this morning, the small centre button on the front panel will not press. All the dials are set to '0' and the screen displays STOP. Usually...
the same has happened to mine. i used it last night as usual and this morning the button just wont press?? did you manage to find out what was wrong?
thank you x
Aug 08, 2010 | Whirlpool AKZ159IX Oven
I HAVE A MAYTAG BUILT IN OVEN THAT WAS WORKING FINE LAST NIGHT AND GET UP THIS MORNING TO BAKE AND I AM GETTING, ITS FLASHING A F2 AND F7 ERROR CODE AND THE ALARM OR BEEPING IS GOING OFF
Hi You have a bad touch pad , there maybe a be a button stuck in , try running your fingers over all the touch buttons but i think the touch pad will need to be replaced as always remove the power before taking it a part
Dec 21, 2009 | Maytag CWE4800A Electric Single Oven
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Sep 23, 2009 | Jenn-Air Ovens
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
My cooktop is locked and I don't know how to unlock it. I did a self clean last night and the oven works fine.
Push in on the oven light switch and hold in for about 5 seconds cook toplight switch will go out same to lock it again.
Jan 24, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven works when it is open
sounds like the oven door switch got bent or misaligned
Dec 20, 2007 | Bosch HBL 5056 Electric Double Oven
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
AEG D5701-4 Electric Double Oven Logo
26 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
