Question about Maxi-Cosi Baby Gear
Last green light does not appear when fitting car seat to the cabriofix ?
5 Suggested Answers
  • 3 Answers
SOURCE: fitting cabriofix car seat with seatbelt only
yeah i had a cabrio and just fitted it in car with the seat belt the part of the seat belt that would go around your waist goes over the front of the carseat and over were the baby would be sitting there is clips at either side just below the carryhandle put the seat belt through them then put the part of the seat belt that would go around your neck round the back there should be another clip in the middle of the back above the storage part if you put the seat belt throgh it then clip the buckle in and pull tight the car seat should be secure hope i explained it easy to follow.
Posted on Nov 03, 2008
  • 419 Answers
SOURCE: Hi, weare missing the bars that fit under the
If you purchased the carseat without the bars, then this is a Cabrio and not a CabrioFix carseat, and nothing can be done to adapt this to become a CabrioFix.
I hope this helps.
Posted on Sep 15, 2009
  • 419 Answers
SOURCE: How to fit a maxi cosi cabrio car seat - note it
To fit the Cabrio (with seat belts only), follow these steps:
Note that you will have three metallic looking blue seatbelt hooks (made of plastic) on the Cabrio. One is at the back to carseat (directly behind the childs head) and also there is one either side of the child (when seated in the carseat), these hooks are used to slip the seat belt into and therefore secure the seat.
Placing the carseat facing the rear windscreen of the car - if this is in the front seat, then ensure that your airbag is disabled if you have one. If this is not possible, then DO NOT use the front seat.
Ensure that the carseat handle is clicked into the 'carrying' position, upright.
Taking the seatbelt in your hands, slip the lapbelt through the two blue hooks which are either side of baby and then click the seatbelt into the buckle. Pull firmly so it's nice and taut, hold onto the carseat when you are pulling the seatbelt.
Whilst taking the slack with one hand, take the shoulder seatbelt and loop through the third blue hook (located on the back of the carseat) and again pull firmly whilst holding onto the carseat.
When you attempt this, practice without the baby in as this is much easier to do.
Finally, check that the buckle of your seatbelt is not resting too high or on an angle of the cabrios plastic shell, as this is considered dangerous and is called 'buckle crunch', for more information on this, please see the link below, which explains with images:
http://www.childcarseats.org.uk/choosing/fitting.htm
I hope this helps.
Posted on Oct 04, 2009
SOURCE: Is the maxi cosi cabriofix car seat compatible
I just called the Maxi Cosi customer service line to ask this question. No, the carseat base for mico will not work with a cabriofix carseat- different shape.
Posted on Jan 05, 2010
Maxi cosi cabriofix stuck
Hi
The description provided is how the EasyBase will appear when a carseat is NOT on it. The indicators will go green only when a carseat is correctly locked in place on the base and the grey handle will go in.
Jul 11, 2012 | Maxi-Cosi Baby Gear
I bought a replacement car seat cover on-line for my Maxi-Cosi CabrioFix infant car seat. When it arrived, I noticed that the white and yellow 'Warning' label on the front had writing in Chinese and other...
Maxi Cosi fabrics only have the Side Protection System tag if the seat they are designed to fit has the SPS technology (not all seats do). Make sure you have the correct fabric for your carseat.
Oct 07, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
I need a head support for my cabriofix car seat
Although you can buy generic head huggers that will fit fine, you could contact www.maxi-cosi.com who will be able to help you to buy the branded version.
I hope this helps.
Sep 05, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
I hope this helps.
Aug 14, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Fitting cabriofix car seat with seatbelt only
Oct 28, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
Which car seat fits the Quinny zapp
Hi, all the maxicosi carseats will fit onto the zapp using the adaptors that come with the zapp pushchair (but not the newly rebranded bebe loola).
The difference between the maxi cosi cabriofix and the ordinary cabrio or citi is that the cabriofix can be attached to the maxicosi in-car seat base (easybase or easyfix), whereas the cabrio and citi can only be fitted in the car using the cars seatbelts, they wont attach to the incar base. Hope I have helped a bit x
Aug 31, 2008 | Quinny ZAPP Stroller
Baby Gear Logo
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
