Question about Moen 3867 Four Function Hand Shower With Slide Bar
Shower head will not titghten up and stay in position
2 Suggested Answers
agent91
  • 2100 Answers
SOURCE: leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Posted on Mar 16, 2010
Shower with hose is loose and wont stay in position
Probably it is due to a losen hand shower holder. You need to take it out and fasten it.
Feb 05, 2014 | American Standard Plumbing
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
Keeps going from boiling hot to cold
At a guess either the shower head has become clogged/calcified or the piping inside the shower has become so.
This means that water stays in the system too long, becomes over heated and the failsafe cut off activates.
Try cleaning or replacing the shower head.
Jan 30, 2012 | Neptune Home
When lever on tub spout is pulled up for shower use some hot water still comes out of the tub spout...reducing water pressure and temperature of water coming out of the shower head... Tub spout does NOT...
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
Leaking shower head
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
The shower head was in place for over a year. Then when my daughter was taking a shower the whole ''T'' head flew off at her. I've tried to reinstall a couple of different times but it keeps flying off...
just replace your shower arm that is what the shower head is connected to make sure you use teflon tape around the threads on each end of the shower arm that should do the trick
Mar 07, 2010 | Culligan & Hand Held Filtered Showerhead
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Moen 3867 Four Function Hand Shower With Slide Bar  Logo
63 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
