Look at the various videos online (youtube and fixmyhog). The main thing is to not spill oil when removing the oil filter. Ruins the front engine mount.
IF you are running stock pipes (not "True Duals"), the right pipe exhaust ALL from the front cylinder, and SOME of the rear, and the left pipe only blows SOME of the rear alone.
The stock rear pipe splits, some going to the left pipe by itself, and the rest going to the right pipe WITH the exhaust from the front cylinder.
Now, white smoke usually indicates moisture.
Being a (non-VRod) Harley, that eliminates the liquid coolant, because there is none.
Next up that comes to mind is condensation.
BUT, this would burn off fairly quickly.
So is the white smoke only at first, or even when warmed up?
And if warmed up, is it actually coming OUT of the pipes, or OFF the pipes (like some oil burning)?
Regarding 2001 audi a6 quattro 2.7t....i was driving to work the car was fine then white smoke starting coming from under the hood and tail pipe. i stopped veilce and alot of oil was dripping from front of car. I towed it home and i looked under the hood and there was oil from valve cover gasket. i let the car sit for a few days, had it running again for a good hour and no white smoke was coming out. I removed the valve cover and gaskets are all bad. i want to know can the valve cover gasket leak cause the white smoke to come from exhaust pipe?
this could be the valve stem seals that needs replacing it is rubber seals inside the cylinder head each valve has one their function is to prevent oil in the cylinder head from ending up in the combustion chamber now because the vehicle is not used that often they become brittle and hard and therefore no longer serve their purpose
White smoke out of the tail pipe may be an indication of a bad head gasket in the engine. Pull your oil dipstick out and see if the oil looks a little milky.
As u know - that smoke is oil . can be cause by restricted breather or oil filter, worn valve guide or seals. or a bad piston ring which seems the most likely if its just coming outa one pipe. A compression test will tell ya if thats it
