Question about Dell Inspiron 8600 Notebook
DELL INSPIRON 1410 idle process takes high processor usage and heats up my pc
When idle, the pc is working hard and 50% of cpu is busy and fans are running heating up and making noise
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
If running Windows OS - there could be several background processes running causing this higher CPU usage.
Hitting 'CTRL/ALT/DEL' will bring up the task manager (Win98/WinXP) or a Menu which has task manager (WinVista/Win7/Win8), you can then see what background programs are running.
Posted on Nov 21, 2013
kykeaton
  • 35 Answers
SOURCE: Dell c640 overheat
There would be no way to know if that is the case without opening the machine. I suggest taking it to a certified
laptop repair technician near you ( a Dell Store if under warranty ), and explaining the issue to them. I have not seen
this happen myself ( the heatsink popping off ) but that's not to say it can't happen. I suggest having the laptop
looked at sooner than later, as each time you turn it on and it overheats it reduces the life expectancy of your
unit.
Posted on Feb 24, 2008
Vegggie Boy
  • 28 Answers
SOURCE: Laptop running hot - Fan cycling on and off every 10-20 seconds
My guess is that CPU fan, it there is one, is not working properly and your computer is heating up. Is it turning off, too, occasionally after a period of time? Suggest a new CPU fan.
Posted on Jun 14, 2008
ArmyMason
  • 121 Answers
SOURCE: 2 ghz processor running at 220 mhz
Have you tried right clicking on the desktop (opening Display Properties), clicking on Screen Saver tab, Clicking the Power button, and setting the power schemes to Home/Office Desk? If its set on laptop it will reduce the processor speed when running on battery. I have noticed that even with it plugged in that some times it will run at half processor speed. Try that out.
Have a great day,
Armymason
Posted on Mar 02, 2009
  • 58 Answers
SOURCE: Dell inspiron 9300 17inch makes crackling sound then shuts down
Please try to upgrade the BIOS version and flash the BIOS. Please check the link and follow the instructions: http://support.dell.com/support/edocs/systems/ins1525/en/SM/bios.htm#wp1179839
Posted on Nov 04, 2009
  • 3940 Answers
SOURCE: Dell Inspiron E1505 will power off after 3 seconds
If the system will not run long enough to run diagsnostics, I'd replace the heatsink and the fan
Posted on May 14, 2010
Dell inspiron 2020 all in one fan problems
I have found that if the room temperature near the computer is too high creates a problem. If the processor is being used at a high rate that will influence the temp sensors and cause the fan to run at the "speed" you hear. (It is on all the time, just different speeds). Other heat producers may not have clean fans or fins, for example display adaptor or power supply. or but unlikely, the
cpu fan interface is not well seated or no heat transfer grease. You didn't change the processor did you?
Apr 05, 2015 | Dell Inspiron One 2020 Desktop Intel Core...
Tip
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
or
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
ANY SUGGESTIONS...?
on Feb 16, 2011 | Computers & Internet
Dell inspirion 1545 respond slow and shuts down even when on the desktop
The most probable, as far as I know, the hard drive is dying. Please test the laptop with a healthy (or brand new) hard drive.
Feb 18, 2014 | Dell Inspiron 6400 Notebook
Computer not responding at all
If it burnt a new HDD then the problem could lie somewhere on the mobo. If it's still under warranty, i'd suggest RMA. Otherwise, you will have to take it back to the computer repair shop and listen to their suggestions.
Jan 09, 2014 | ASUS Eee PC 900 Notebook
Dell Inspiron1410 running 50% CPU usage with no other processes running in background. This after a nice repair install of Windows XP professional. High fan noise and heating up! Thanks
Hello Saman Tarik,
Task manager may say there are no other processes running but if you look in the next tab, "Services" you will find there are many things running.
The processor will run at a lower percentage when it is not busy.
As for running hot, I would suggest that the heat sink fins need cleaning out, I was surprised at how much fluff had accumulated in them, preventing a good air flow.
I have upgraded my processor from 1.5Ghz to 2.5Ghz which runs hotter so I bought a ZALMAN ZM-NC1500 USB and the hottest my CPU has reached is 41 degrees when both cores are running at 100%.
I hope the above information is of use to you.
Kind regards,
Ron.
Nov 21, 2013 | Dell Inspiron 8600 Notebook
Why do I always get high cpu in windows 7 home edition-Dell inspiron when playing videos, games or music
High C.P.U. usage reading when playing vidios or games is normal the c.p.u. takes up processing tasking to offload the graphics processor in order to provide maximum framerates at a given resolution, pixle shading, colouring etc. I would not worry about it as this is normal. Just try to give all computers the best ventilation possible, with laptops it is important to have them on a flat hard surface. Not carpet or table cloths etc. as laptops have cooling vents on the underneath.
Oct 09, 2011 | Dell Inspiron 1545 Notebook
I have a dell 8400 tower that operates just fine usually but lately there seems to be a fan issue where it sound like a jet engine and I am concerned that the fan will fail (it currently operates) and...
the bios monitors the processor Temperature and increases fan speed if its gets hot. I recommend, get a can of air and blow out the processor's heat sink, as it could be getting dirty and preventing air flow for cooling. otherwise you have some software that running the CPU at a high rate for a long period of time. Use control +alt +Del then switch to task manager, if you click on the CPU heading it will order the tasks by CPU usage, look for the ones that are at the top of the list. note:system idle process should always be way up there 95-100% CPU, this on is OK. all else look into. you can "end task" one the offensive one and look up more details on the web about that application. I look forward to your comments. Thanks
Aug 27, 2010 | Dell (Fan Only) M/N AFC0912DE, DC12V,...
My Dell, recently got into a problem like it shuts down itself, only when i watch online movies. I started watching online movies eight months back but did'nt have this problem till last week. Its a Dell...
Without knowing anymore specifics, I'd guess to say that's its a heat related issue. Especially since it's summertime now and you're on a laptop. Note that when viewing online movies, especially if you choose hi-def over std-def, your laptop will use much more horsepower and thus create more heat than if you were just cruising the internet or working on an Office application. And when viewing a movie, you're doing this consistently for an extended amount of time. Eventually, your computer reaches a temp(usually specified in your computer's Bios) where it will either shutdown or restart in order to cool-off.
To verify and understand this, please perform the following steps:
1) Close any open programs, especially any internet browsers, and make sure your antivirus isn't performing a full scan.
2) Right-click on the taskbar (or hit Ctrl-Alt-Delete) and select 'Task Manager'
3) Now click on the 'Performance' tab.
4) Take note of how much 'CPU Usage' you're using. For example, I'm on a laptop, at idle, and it says 3% CPU Usage.
5) Now, open up your browser and go to where you watch online movies but don't start any videos yet.
6) Take note of the 'CPU Usage' now. Currently, I'm on Hulu and on average I'm at 8% CPU usage.
7) Now, start watching your online movie and take note of the 'CPU Usage'. For me, it jumps between 40-50% on std definition and 50-60% on hi-def.
So what's the solution if it's heat related, well for a laptop your best bet is to buy a laptop cooler (look for reviews online). I recommend any retail store or buying online from NewEgg, Amazon, or Buy.com. Also make sure any vents from the laptop aren't obstructed.
Now to keep a better eye on your laptop's temperature, I recommend the following 100% free, no spyware, no viruses, no adware programs:
(Note: after you install one of these, you may want to repeat the steps above and take note of the temps during each step)
HWMonitor
http://www.softpedia.com/get/System/System-Info/HWMonitor.shtml
Real Temp
http://www.softpedia.com/get/System/System-Info/Real-Temp.shtml
Core Temp
http://www.softpedia.com/get/Windows-Widgets/Widget-Miscellaneous/Core-Temp.shtml
CS Fire Monitor (CPU Usage tray display, etc)
http://www.softpedia.com/get/System/System-Info/CS-Fire-Monitor.shtml
Aug 10, 2009 | Dell Computers & Internet
Jun 14, 2008 | Dell Inspiron B130 Notebook
Delayed keyboard response on Dell Inspiron E1705 Laptop
Is the mouse response sluggish as well during these times?
In most cases, it means the computer is busy with another process. The keys you press stay in the keyboard buffer until the CPU has time to process them.
Check your CPU busy time when this happens. In Windows XP, press ctl-alt-del to start the task manager, the select the processes tab to see if one process is tying up the system (by % of CPU), or press the performance tab to see CPU usage. If it is pegged at close to 100%, something is tying up the system.
May 12, 2008 | Compaq Presario 700 470024-192 Notebook
Dell Inspiron 8600 Notebook Logo
51 people viewed this question
Alun Cox
