Question about Plantronics M55 Bluetooth Headset
Reset m55 how to reset my device
Toshiba satellite m55-s3315 hard drive password reset
Yikes. I'm not calling you a thief, but 99% of the time when you encounter a computer with a password on the hard drive and the possessor of the computer does not know the password, the computer is stolen.
May 28, 2012 | Toshiba Satellite M55-S135 Notebook
How to reset toshiba satellite m55 s1001 without disc
You need the recovery disks one for Windows and one for the device drivers.
This WEB site can provide the recovery disks.
http://recovery-disks.com/toshiba/toshiba-satellite-m55-s1001.html
Aug 26, 2011 | Toshiba Computers & Internet
No appear in my deskop proprieti output monitor because missing the,, ialmnt5.sys driver'' Please help me !Thank you so much ! I have one lap top Toshiba Satellite M55-S135
The ialmnt5.sys file is a driver file for video cards. The best solution in this case is to reinstall the video driver.
Go to the manufacturer's support website to download the latest drivers for your device.
Here is the link for your laptop drivers : Satellite M55-S135 drivers.
Make sure to select the correct OS version to get compatible and working drivers.
Hope this helps.
May 19, 2011 | Toshiba Satellite M55-S135 Notebook
Reset Toshiba Satllite m55-s141 Bios Password
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 13, 2010 | Toshiba Satellite M55-S141 Notebook
Which usb ports are 2.0 speed on my m55-s3512?
Well, with the usual efficiency of Toshiba, I can't locate the M55 series laptops to lookup, the M50 does seem to be similar though and all the USB ports there are 2.0.
Easiest way? Find a new USB device (memory stick for example) and plug it into each port in turn. Give windows enough time to detect and install it, and if it's a USB1 port, you'll get a message saying "This device can perform faster in a USB2 port".
Mar 01, 2010 | Toshiba Satellite M55-S3512 Notebook
NO SOUND DESPITE AUDIO DEVICE WORKING PROPERLY
click start
then control panel
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
even if there is no yellow !mark follow the steps and update or re-install the driver
Hope this helps
Dec 21, 2009 | Toshiba Satellite M55-S329: M55-S329...
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Lan driver
Go to the following site.
1. Choose Category = Portables
2. Choose Family = Satellite
3. Choose Model = M55-135
Filter on Lan and the drivers come up for XP
If this doesn't work list the detail specs from the device manager on the specific component you want and it can be found.
Jan 29, 2009 | Toshiba Satellite M55-S135 Notebook
Plantronics M55 Bluetooth Headset Logo
250 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
