Question about KitchenAid Food Mixers
Kitchenaide mixer makes grinding sound
Mixer runs but makes a grinding sound as it turns. The faster it turns the louder the grinding sound.
3 Suggested Answers
  • 143 Answers
SOURCE: grinding sounds and slower mixer speeds
It sounds like you may have a broken worm gear inside your mixer which is a common problem.It is a wearable part which transfers the power from the motor to the main drive. It may be chipped or damaged right now, and running it will cause more damage. Part number for the worm gear is W10112253. This does however require some know how to replace. Hope this helps
Thanks
Posted on Nov 22, 2009
  • 447 Answers
SOURCE: Kitchenaid mixer running too fast.
Change the speed control board. Repair alot of these
Posted on Dec 24, 2009
My kitchenaid artisan mixer doesnt run fast enough
It may be seizing up the bush that your accessory drive runs in, if you can see grindings in the front by the square drive that is a sign. Here in NZ that bush is only available as part of that whole top cover/housing. The accessory drive gear will also need to be replaced.
Feb 17, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Tip
KitchenAid mixer making grinding sounds.
Is your KitchenAid mixer making loud grinding sounds and running slow? This is a common problem with these mixers. One or more of the screws holding the beater drive mounting plate in, has backed out, and is rubbing against the plate making a loud grinding sound and slowing the unit down.
The solution involves removing the beater driver shaft and plate and taking out all the mounting screws, then reinserting them with lock tite, available at Lowes or Home Depot in the hardware department.
The beater shaft, located vertically, has a pin in it which needs to be driven out with a punch and hammer. Then a "C" clip must be removed from the base of the shaft. You will need some "C" clip pliers available at any automotive parts store. Using the pliers insert them in the holes in the "C" clip ends and squeeze the handle. This will spread the "C" clip and allow you to slide it off the shaft.
Next pry the chrome bezel off around the exterior of the shaft which will expose about 6 screws which need to be taken out. These are the screws causing the problem. They should be removed one at a time and replaced with lock tite added to the threads.
Reassemble the mixer after all the screws have had lock tite added. This should quiet your unit and make it run faster.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 01, 2010 | KitchenAid K45SS Classic Stand Mixer
Kg25h0x stand mixer
Sadly the only help we can give is SUGGESTING you contact Kitchenaide and have them assist you
Oct 17, 2017 | KitchenAid Professional Heavy Duty Series...
On low it makes a really loud grinding noise the higher you turn up the speed the slower it becomes.
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
Jun 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer makes a loud ticking or clicking sound at low to moderate speeds, like a clock tick. At faster speeds and high speed, the loud tick is drowned out by a louder grinding sound. All of this sounds...
I don't have a direct answer for you. There are many things which could cause the noise from a beater simply hitting the bowl to internal gear problems. You did not say which model you have so take a look at the two Service Manuals linked below. One of these ought to cover your machine.
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
Apr 06, 2017 | KitchenAid Food Mixers
Dec 24, 2009 | KitchenAid K45SS Classic Stand Mixer
The attachment/accessory "screw" fell into my mixer while the beaters were mixing a cake batter. The mixer froze up when it hit the "Screw" and now the unit won't turn on. Did I burn up the motor? Does...
Sounds like a classic case of the gears jumping out of sync. This is an issue that needs to be handled by a repair place or sent back to KitchenAide. The motor on a KitchenAide is very strong and it sounds like when the cap for the accessory fell in it must have somehow gotten jammed, although I really don't see how that would be possible unless there was something else in the mix as well.
Dec 04, 2009 | KitchenAid K45SS Classic Stand Mixer
Grinding sounds and slower mixer speeds
Thanks
Nov 21, 2009 | KitchenAid K45SS Classic Stand Mixer
My Kitchen Aid KSM150PS Artisan red mixer trembles alot and makes a grinding sound when I use it. I've exchanged it once already and have the same problem again.
Kitchenaid mixer are supposed to make a slight grinding sound while operating under load. This is simply the gears meshing together while the motor is turning them, but if the sounds gets worse or is already a metal grind type sound this could indicate a broken worm gear inside the unit, and shouldn't be run any longer. However if your mixer isnt on SOLID ground this could cause the tremble as well.Hope this helps
Thanks
Oct 31, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
24 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
