Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to edit registry
1)pls teach me how to edit regisry 2)pls teach me what is bat file and its use 3)how i can create an auto run programe
    Problem Solver:
  • 5 Answers
1)Click Start+Run then type in regedit 2)A file that contains a sequence, or batch, of commands. Batch files are useful for storing sets of commands that are always executed together because you can simply enter the name of the batch file instead of entering each command individually. In DOS systems, batch files end with a.BAT extension. For example, the following DOS batch file prints the date and time and sets the prompt to GO>: date time prompt [GO>] Whenever you boot a DOS -based computer, the system automatically executes the batch file named AUTOEXEC.BAT, if it exists. Many operating systems use the terms command file or shell script in place of batch file. 3) create the file ?AUTORUN.INF? in the CD's root directory and put some simple commands in the file to indicate what you want to be auto-run. The file ?AUTORUN.INF is a simple text file - use notepad to edit it. For example to create a CD that will autorun the program ?setup.exe? would require an AUTORUN.INF file similar to: [autorun] open=setup.exe icon=setup.exe
Posted on Oct 08, 2007
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
  • Terry Allen
    Terry Allen Jun 18, 2014
    Ms Dos hasn't been used since 1980 It has been replaced the command prompt simular to the dos program but with the invention and tuning of of the operating systems. The dos program was on a set of 6 floppy disks ans was how it was installed on the disk.
My program file regsvr.exe delete.How restore this
Dear Amartya,
Here is a solution for your problem.
What the regsvr.exe virus does?
• This worm creates folders and a registry entry to enable its automatic execution at every system startup.
• This worm also creates a scheduled task to enable its automatic execution at a specified date and/or time.
• It also creates Autorun.inf file for its auto execution.
Solution to fix the problem:
1. If the task manager and registry editor is disabled then we need to enable them first. Read this post.
2. Delete the Autorun.inf file created by the virus. Read this post to know how to do that.
3. Now type msconfig in the Run dialog and click on startup tab.
4. Look for regsvr and uncheck any options, click OK.
5. Now traverse to control panel -> scheduled tasks, and delete the At1 task that might be listed there.
6. Type regedit in the Run dialog to open the registry editor.
7. Click on Edit -> Find and search for regsvr.exe
8. Just delete all the occurrences of regsvr.exe virus (do not confuse it with regsvr32.exe which is not a virus).
9. Navigate to entry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon and modify the entry Shell = "Explorer.exe regsvr.exe" to delete the regsvr.exe from it.
I think it helps.Let me know
Best regards
Chandrashekahr Bhat
Dec 25, 2010 | Microsoft Windows XP Professional
Removing write protection
In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from, and double click after download the key will be automatically added to registry.
You will get the box like this
3. Double click the key WriteProtect in the right panel and set the value to 0 in the Value Data Box and press OK button.
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
on Jul 21, 2010 | Computers & Internet
How to create a batch file on windows xp.
To create a batch file that would be very helpful I suggest downloading notepad++ it's made for programming.First off open up notepad++ and go to
languages and click on batch then type in "@echo off" at the beginning of every batch file you need to type that in.Next type in:
@echo off
echo What would you like to do today?
echo 1)Notepad
echo 2)Paint
echo 3)Calculator
set /p web=Type in Option:
if "%web%"=="1" ("%SystemRoot%\system32\notepad.exe") else (exit)
if "%web%"=="2" ("%SystemRoot%\system32\mspaint.exe") else (exit)
if "%web%"=="3" ("%SystemRoot%\system32\calc.exe") else (exit)
You just created a batch file menu now save this file to the desktop as
"Menu.bat".Now that you have the file saved download this free batch file compiler called "battoexe" so nobody can edit or destroy you batch files.
That's it you have made your first batch file visit my website at
on Jul 18, 2010 | Computers & Internet
How to activate task manager on my pc
It can be done easily by editing the registry. I will try to explain in detail. Follow these steps
1. Check that your PC is virus free. Install Antivirus program if required.
2. Regisry is enabled. Goto run command from start menu OR Press Win key+R and type 'regedit'. It would show up registry.
3. If registry is enabled you can edit it.
4. Open notepad and paste the following four lines
Windows Registry Editor Version 5.00
6. Choose 'all files' option from 'Save as type'
7. Now you should have a registry editing patch. Please note that its extension is .reg
8. Double click the patch to add it to registry and task manager would be enabled.
9. Alternatively, you can download PROCESS EXPLORER, whichis a replacement of task manager from internet. It works even if the taskmanager is disabled.
Hope this helps. Let me know if you need any further clarification/ help
Nov 12, 2010 | Computers & Internet
When i was connected internet my pc has slowed down at home . is there any solution?
Hi Good day!! Remove unused programs in your computer. run disk cleanup remove unnecessary files. if still slow I'll suggest to you to increase your RAM (memory). RAM (Memory) can improve your loading performance.
Thank you for using FixYa
Don't forget to vote thanks!!!!
Nov 04, 2010 | Microsoft Windows XP Home Edition
When i copy a kind of file to my 4gb kingston data traveler it say "the device is write-protection or another disk solve this problem please please
Hi Friend,
Please make sure that the physical lock (if provided on the pen drive) is properly unlocked.
After doing that, kindly follow the steps:
1.Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2.Navigate to the following path:
If the registry key StorageDevicePolicies key does not exist, you will need to create it. To create and download the batch file add.bat please click the link below
3.and double click after download the key will be automatically added to registry.
4.Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
5.. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer.
I hope this will resolve the issue.
Sep 16, 2010 | Computers & Internet
How to remove the parasite variant cftmon32 .exe and Ati hot key poller in system32.. HJT v fixes them but they return after 2 or less subsequent scans. Ati hot key poller in system32. always...
cftmon32.exe is a malicious code created to change security processes and registry files and execute different malicious behavior on your computer. Once installed on the PC, cftmon32.exe may automatically carry out mischievous payloads at system start up by creating entries in registry. cftmon32.exe my compromise your privacy and slash computer security.
Follow the given steps for removing virus
1. Temporarily Disable System Restore, Reboot computer in SafeMode
2. Locate CFTMON32.EXE virus files and uninstall CFTMON32.EXE files program. Follow the screen step-by-step screen instructions to complete uninstallation of CFTMON32.EXE.
3. Delete/Modify any values added to the registry related with CFTMON32.EXE,Exit registry editor and restart the computer
4.Clean/delete all CFTMON32.EXEinfected file(s):CFTMON32.EXE and related,or rename CFTMON32.EXE virus files
5.Please delete all your IE temp files with CFTMON32.EXE manually,run a whole scan with antivirus program
Aug 19, 2010 | Microsoft Windows XP Home Edition Service...
regedit - to disable this file from running, delete it. if you want to turn off the registry, boot computer into safe mode (tapping f8 key while booting). if you need to manually uninstall a program, do an F3 search in the registry for the program name as a search string. there can be as many as 500 registry entries for the program... if you adopt the f3, delete, enter, f3, delete, enter, you may be able to uninstall the program's registry entry in as little as 15 minute to 1 hour... best of luck, I am not responsible if you delete a wrong value and crash your computer .... heheheeheheh.
Sep 26, 2008 | Red Hat Enterprise Linux ES 3 Standard...
Antivirus 2009
I see these every day, note: also fixes AV 2008 and many others.
This Malware is known as "Rogue anti-virus" software.
This program will remove it:
the website that has it also has a really good antispyware program called malwarebytes
once you run a full scan in this program run this program:
it's another free antispyware. these are both professional grade removal software for free. I remove this stuff about 3 times a day. It seems this outbreak is the largest I've ever seen.
If you want a good protection suite that will keep it out buy a copy of NOD32 ( another you may not have heard of, it will block this and many others before it even gets on your computer.
Jul 17, 2008 | Balance CN6555 Notebook
Pls verify that you are logged on as Administrator and that no other related software are running such as Ad-Aware or ZoneLabs. It would seem further that you would need to contact AVG / Grisoft and for then to send you a batch file that you need to run before installing AVG 8. The file is named "reset_access.bat". After the bat file, the installation should work. The bat file is supposed to clear up some permissions issue that will allow the installation to proceed.
Alternately, you can Try downloading this files from this link .
Decompress the zipped file (extract) to a folder in your C drive and run reset_access.bat , it should fix the registry problem and allow installation.
Or you can try manually editing your registry by deleting the entry HKLM\SOFTWARE\Classes\AvgDiagFile\DefaultIcon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 06, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
285 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
