Question about Sony CDP-C265 CD Player
Sony cdp 501es loading gear - Sony CDP-C265 CD Player
I need the 3 belts for sony cdp cx355 cd player. Do you carry these belts
here are the belts. http://www.ebay.com/itm/SONY-CDP-CX300-CDP-CX335-CDP-CX350-CDP-CX355-CDP-CX400-Drive-Belt-Kit-3-belts-/152184107208?_trksid=p2141725.m3641.l6368
Nov 10, 2016 | Sony Audio Players & Recorders
Sony CDP-CX400 Mega Storage CD player having issues ejecting disk. Can Load Error be cause by worn and "out of tension" belts? Table turns a bit slow and when I hit disk eject
Either a loose loading belt, or a weak loading motor can cause this fault. Check it. A weak loading motor can cause more faults. If the pulling power of this motor is low, the fault will occur. Replace this motor and the loading belt first. Check whether there is any gear wheels having broken teeth.
Feb 23, 2016 | Sony Audio Players & Recorders
The disk tray will not open, and after a brief time the word ERROR appears in the display window. Is there some power on button combinations to reset the processor?
The fault is with its disc loading mechanism. Contact any service technician. Disk is not loading properly into the system. A loose loading belt, or a broken gear wheel can be the cause.
Jul 31, 2015 | Sony CDP-CE375 5-Disc Carousel-Style CD...
Disc will not load on sony cdp cx400
Loader mechanism fault. Not engages the CD properly to desired tray section. Contact any service technician. The loader tray should be repaired, and this is not a user repairable fault.
Oct 17, 2014 | Sony CDP-CX400 400-Disc CD Changer
Sony CDP -CX200 Arm comes forward to pick up cd but goes back empty. It will not load the disc to play.
Is the second part of the arm clamping the cd? If not then the arm is probably broken and needs to be replaced.
Dec 28, 2012 | Sony CDP-CX70ES CD Player
My cdp-455x is showing a loading error after the lazer being cleaned
The laser eimission might have stopped. The laser pickup unit [optical pickup unit] should be replaced.
Apr 17, 2012 | Sony CDP-D11 1U professional compact disc...
Have Sony cdp-c535 cd player. The door won't stay in. Keeps cycling in and out.
I had the same problem with our 5-CD Sony carousel player CDP-C535 (manufactured Nov 1993). I removed the top metal cover, and loaded five audio CDs into the carousel. After I closed the table, I pressed the carousel tight so that it stayed close, and hit the play button. The CD player tried to push the carousel out with quite a force. I needed to warp me fingers around the front panel to keep the carousel closed. After a few cycles of forcing the carousel to remain close, and caused two separate strong "clucks" from the gear area, the CD carousel became operational again. The diagnosis of gear problem seems right.
Nov 28, 2009 | Sony Audio Players & Recorders
I need a user manual to down load for free for a Sony CDP 3x 300
Hello.
Welcome to Fixya.
Please Download Your Manual from the link below:
Sony CDP-CX300 Manual Guide
Good Luck.
Nov 06, 2009 | Sony CDP-CX300 CD Player
In/out dial on bottom of Sony CDP-C305 ... what does it do?
It is Transit Key to protect optical lens mechanism from shocks while transportation unit. remove it before playing unit.
Aug 06, 2009 | Sony CDP-C305 5-Disc CD Changer
Sony CDP-710 belt wanted
www.studiosoundelectronics.com
Please rate my help . Thanks
Feb 01, 2009 | Denon DRM-555 Dual Cassette Deck
Sony CDP-C265 CD Player Logo
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
