Question about General Electric Profile PGCS1PJX Bottom Freezer French Door Refrigerator
GE pgcs1pjx replace light - General Electric Profile PGCS1PJX Bottom Freezer French Door Refrigerator
GE JNM 1851 microwave display panel light is out
The GE Answer Center is telling it like it is. Bet it's touted as a customer-friendly "improvement".
Sep 05, 2017 | GE Microwave Ovens
Pgcs1pjx light does not work
well you have an LED light assembly, what this translate to is it may the light fixture, but unlikely. most likely is a computer board on the back of the fridge. I would call for service for them to trouble shoot to insure you get the right part the first time. both parts are a bit pricey.
Apr 08, 2012 | General Electric Profile PGCS1PJX Bottom...
Water dispenser isn't working and door alarm isn't sounding when door is left open
Easy one. The fridge computer has crashed. Remove and reapply electricity to fridge (via the circuit breaker).
Jan 12, 2011 | General Electric Profile PGCS1PJX Bottom...
Freezer not cold
have you check the fan inside the freezer? see if it is running.
see also the fridge if it is cooling, if both side are not then there something to do with your compressor, it's either under charge(leak is the cause) or lost compression (mechnical failure inside your motor compressor)
Nov 06, 2009 | General Electric Profile PGCS1PJX Bottom...
GE Profile Convention Light Bulb Not Working after Replacement
With a volt meter you must verify power to the door light switch and the light socket.
You can also unplug the oven and do this with a meter set for continuity.
Feb 17, 2009 | GE Profile JTP18 Electric Single Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
General Electric Profile PGCS1PJX Bottom Freezer French Door Refrigerator Logo
50 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a General Refrigerator Expert? Answer questions, earn points and help others
