Question about BSA Riflescope Platinum 8-32x44 TT Matte Black Optics
I have a harddisk, 320 GB, model no. 124551 and serial no. 205779
PLATINUM hdd
MY QUESTION IS HOW DO I Disable the "SECURITY FREEZE LOCK" on my hitachi HTS54503289a300, 320 GB sata hard Drive? originally WAS INTALLED IN MY ACER TRAVELMATE LAPTOP NANUFACTURED IN 2012 BUT THE LAP
Maybe if you can format the disk-but you loose data, maybe there is a program that can do it, probably in linux, or bootable itself, maybe ask acer for master password or something, if you still own original laptop and it runs then try to remove disk encryption while the hdd is accessible with laptop (i think its in bios), otherwise the hdd may be unusable to prevent data theft. you can plug any sata hdd into any sata device if you can hook all the cables, no compatibility issues there. try googling and youtubing for more answers
Sep 14, 2014 | Computers & Internet
Faulty circuit board of clickfree hard drive hd325. Where to find the board. Pls! Help!
This is en external HDD. This means, there's a HDD inside the package, and a small PCB (print with tiny ICs on it). If you're lucky, the PCB is defective, while the HDD is OK. In that case, you only need to look for another USB Harddisk enclosure for a 2.5 inch SATA harddisk. Maybe your local computer-store sell these casings, otherwise check internet (eBay for example)
To be sure it's either the HDD or the PCB, just open up the casing and remove the HDD. Insert this HDD into a PC, connecting it to the motherbord over a SATA-cable (and don't forget to use a powercable too).
If the HDD becomes visible under Windows or whateven operating System you use, than it's indeed the PCB, which is defective. If the HDD is not visible, maybe the HDD is defective. In such case, you can find at internet a new(er) HDD of identical make (brand / type HDD)
Oct 18, 2013 | ClickFree HD325 320 GB USB Hard Drive
Hi, I have got a problem with my Seagate free HDD 320 GB, I lost my original USB cable bought with the Hard drive, then I bought another USB common cable. I tried to connect it prompt the following: Light...
Start -> Run -> devmgmt.msc. Check any yellow marks or explainary marks or red x marks. Right click on that and UPDATE driver.
If not working, please try with another NEW cable..
Jun 17, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Dear Sirs, I need the Windows 98 Driver for Western Digital USB External HardDisk 320 GB ? I use COMPAQ Presario with Windows XP to hook up the External Harddisk right know. The External...
Sory to report - from Western Digital support site
Uses SES Drivers
7, Vista, XP
Not Supported
Server 2008, Server 2003, 2000 Server, 2000, ME, 98SE, 98, 95
Win 98 is not a supported OS, for that drive.
Jan 27, 2011 | Western Digital My Passport Essential...
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
AcerAspire M1641 total capacity of all HDDs limited by MCP73VE mb
It is up to 1TB per drive. RAM is totally different and has nothing to do with HDD capacity.
Jul 23, 2010 | Acer Aspire M1641-U1521A PC Desktop
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
Dec 23, 2008 | Western Digital My Book Essential Edition...
Maximum HARDDISK CAPACITY FOR Intel 865GV motherboard
Yes, your board will support 320gb. I am not aware of a limit to how many gigabytes you can have per computer. I currently have 1.5 terabytes. 1500gb.
Apr 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
BSA Riflescope Platinum 8-32x44 TT Matte Black Optics Logo
24 people viewed this question
Top BSA Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a BSA Optic Expert? Answer questions, earn points and help others
