Question about Philips Health & Beauty
Philips shaver PT 920 has stopped working. It cuts out after two seconds.
Philips Shaver Faulty
Replacement under warranty involves promising to remove the battery from the old shaver and disposing of the battery and the carcass in an environmentally safe way.
The shaver can be split apart after removing three torx screws and then prising the plastic parts apart against their clips. Be VERY careful when releasing the plastic clips inside because they are brittle and fragile.
On opening the cover containing the battery, motor and control circuitry the ingress of water was clear. The shaver is supposed to be wet and dry, has only been used dry but the exterior has been washed.
The water was displaced using WD40. The shaver operated normally straight away. If your shaver's motor starts with the button but stops again half a second later, the problem might be caused by water ingress.
Dec 16, 2013 | Philips Aquatouch At890 Wet And Dry...
What replacement heads will fit a Philips 765 shaver?
for the correct replacement heads, see link below
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters/philips-norelco/norelco-philips-hq56-super-lift-and-cut-replacement-heads-p-249.html
Mar 27, 2013 | Health & Beauty
Philips at896 stopped working
If it's not in warranty, dissassemble the shaver and check for water inside.
Either dry it out in a warm cupboard or displace the water with WD40
Mar 23, 2013 | Philips Aquatouch At890 Wet And Dry...
Need blades for older shaver phillips 4807. have not been able to find
philips norelco HQ56 replacement heads for electric shaver norelco 4807xl cutter blades replacement parts.
Aug 15, 2011 | Philips Health & Beauty
It does nto cut like it use to. The blade is only 6 months old Whats the best way to clean it. It seem to be cutting with only 1 of the triple head
The Arcitec shavers have a poor design which makes it difficult to clean well. The blades can not be removed from their combs, therefore, the only way to clean this is by running them in a cleaning solution. Norelco makes a shaver cleaned that can be used for this. It is available from shaveroutlet.com at the link below. Rubbing alcohol can also be used.
http://shaveroutlet.com/shaver-accessories/norelco-hq200-smart-touch-jet-clean-solution-p-258.html
Simply fill a container about 1 inch deep with the cleaner and then stick the shaver head down into the liquid with it running. Run for several seconds, remove and repeat several times.
Note that if your shaver is badly clogged, this still may not work that well due to the poor design of the shaver heads. If you require replacement, you will also find them at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Dec 14, 2010 | Norelco Arcitec Electric Shaver -...
Need to change cutting heads
philips norelco HQ9 replacement heads for men electric shaver norelco 8175xl cutter blades replacement parts.
Oct 31, 2010 | Philips Norelco 8175XL Electric Shaver
Hi the shaver isnt cutting as good as it should do i need new cutting folis or new cuttting blades? which eather where can i get them from? Many thanks Donna
Philips suggests that the heads be changed every 12 months. If they are 12 months olor older and no longer cut well, they probably need replacing. You will fin replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq6-quadra-action-replacement-heads-p-250.html
Jun 20, 2010 | Philips Philishave HQ7850 Electric Shaver
Put new blades into Norelco 8175xl but shaver does not cut
philips norelco HQ9 replacement heads for electric shaver norelco 8175xl cutter blades replacement parts.
norelco 8175xl replacement heads
Jul 25, 2009 | Philips Norelco 8175XL Electric Shaver
Health & Beauty Logo
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
