Question about Body Sculpture Bc1510 Exercise Bike
I need new pedal straps
Straps on pedals have split and I don't know where to get any more
Where do I get pedal straps for my vital fitness rb 330?
There are multiple sources of "universal" exercise bike pedal straps:
exercise bike pedal straps Google Search
Aug 24, 2017 | Cycling
Tip
Installing a Pedal Strap onto a Bike Pedal
Video about How to Install a Pedal Strap onto a Bike Pedal
  • This procedure will demonstrate how to attach a pedal strap onto a pedal
    • This is even easier when the pedal is attached to the bike but we did not have a bike available so we are showing how it is done with the pedalremoved from the bike
      • Tip: Soaking the pedal straps in hot water can make the strap installation even easier as the hot water will soften the rubber making it more pliable
  • Start on the inside of the pedal (nearest the pedal shaft) by placing the slotted hole in the strap at the bottom of the tab and pulling the strap up and into place as seen in the video
  • Then with the tab on the outside of the pedal, start at the bottom and push the strap up and around the tab into place
  • This is all that is required to install a pedal strap onto a bike pedal
  • That completes the procedure
Installing Pedal Strap onto Stationary Bike Pedal Video
on Apr 28, 2014 | Exercise & Fitness
The pedals have no straps and where they hook on are broken
Fixya does not sell replacement pedals and straps.
Aug 28, 2016 | Exercise & Fitness
Need replacement pedals for my resistant exercise bike
Rob, try any sporting goods that carry bicycles or bicycle repair shop for replacement pedals or order online.Check the attached links for replacement pedals. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VP Exercise Bike Replacement Pedals 1 2 Stationary Bicycle Pedal Set with...
Parts for Life Fitness Bikes Pedals Battery Pedal Straps SPORTSMITH net
Exercise Bike Pedals eBay
Apr 12, 2016 | Cycling
Pedal GT Outpost
Pedals are threaded pretty standard. I'd unscrew your's and send them to your son. Then put on the pedals you want.
Jul 18, 2013 | Groove Tubes 2010 GT Outpost Disc Mountain...
Sustain pedal doesn't work any more - maybe it isn't the fault of the pedal? I don't want to order a new one if the problem is in the keyboard. I'm sorry, I just lent it to summer guests...
take it into a music store and try a pedal there in store. If it works, buy the new pedal and charge the guests. If it does not work, you know it's th TS input on the keyboard
May 20, 2011 | Casio WK110 Portable Keyboard
My Dad is 87 years old and has a small peddle stationary excersiser that he does from a chair. The peddles are too small and he keeps hitting his ankles etc. His feet don't fit into the straps and he's...
You will need a pedal wrench or a fairly thin open end wrench. Pedals are threaded or a good pedal wrench. The left pedal on bicycles unthreads in a clockwise direction and the right pedal unthreads in a counterclockwise direction. The thread back in oppositely. Theoretically they self tighten as you pedal. When buying the new pedals, make sure you take an old one with you to make sure that the threaded shaft is going to be the correct diameter. Any fairly wide pedal with rubber grips would be a good choice. A past customer even used two blocks of wood screwed together through the old pedals as they were too tight to remove. Hope this helps and wish your Dad well.
Apr 23, 2009 | Cycling
Have a Schwinn xr7 exerciser bike, need new pedals or straps
I am not sure what type of bike you have (did not bother looking it up), but I myself too have a schwinn exercise bike (recumbent) and the straps recently broke, and when I sent customer service an email from their site they said they sell replacement straps.
I included the kind of bike I had when I inquired so the price given to me might be exclusive to my bike only, so you'll have to contact customer support yourself to see if they sell replacement straps for your bike and if so how much.
Mar 15, 2009 | Cycling
Body Sculpture Bc1510 Exercise Bike Logo
Top Body Sculpture Exercise & Fitness Experts
Electro Med Services...
John
ray gallant
Are you a Body Sculpture Exercise and Fitnes Expert? Answer questions, earn points and help others
