Simpson swt554 not spinning
Not spinning
Simpson esprit 450 washing machine. Sometimes it will do the final spin and othertimes not spin at all. The machine is 11yrs old.
Probably a timer problem but you need fault finding knowledge and a test meter to find the fault. There are a few other reasons to not spin. You haven't said if you have a test meter or fault finding skills.
Oct 20, 2017 | Simpson Washing Machines
How long is the warranty on a simpson SWT554
check with the service agent but it should be 2 years
check the power at the wall outlet and the lid switch as possible reasons for failure to work
May 05, 2017 | Simpson Washing Machines
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
My simpson ezi set simple washing machine. .won't drain or spin anymore ??
not draining and spinning indicates a problem program board
call a technician for a proper diagnosis and quote
Nov 26, 2016 | Simpson Washing Machines
I have simpson eziset 7.5kg has trouble spinning throws clothes to one side of tub
check that the machine is level
check that the wash bowl is level as a support mount may be failing and the bowl is not level
when it happens redistribute the clothes to a better balance point and re-spin
if it still happens ,seek the services of a washer technician.
Apr 07, 2015 | Simpson Washing Machines
Machine will not turn on no lights simpson swt554 top loader
check the lid isolation micro switch for adjustment
Mar 29, 2015 | Simpson Washing Machines
Swt955sa simpson topload washers but wont spin
i would suspect the motor brushes or something related too the motor
silly question but you do have spin switched on
i dont know your specific machine
but most modern spin speed adjustment knobs
have a setting 'no spin'
ive fixed four last week same thing the wee old lady and three familys .. same issue spin simply switched off
Mar 09, 2015 | Simpson Washing Machines
Simpson eziset750 washing machine that washes but don't spin
Lid switch / drip dry botton on / wash/spin solenoid fried /
Aug 12, 2013 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
