Question about Stihl 44227 - TS360 AVSE Cylinder & Piston Assembly
Stihl ts 360 avs needs fuel and vent lines diagram
Vent lines are missing need diagram
3 Suggested Answers
philwalker78
  • 608 Answers
SOURCE: missing 025 Stihl chainsaw part
Hi, you are correct it is the tank vent. Go to a stihl shop and purchase a new one, regards Phil.
Posted on Jun 04, 2012
hunter19_46m
  • 7482 Answers
SOURCE: I need to see a fuel line diagram for Stihl fs36 trimmer
Hi Lee Milleer
I hope this is what your looking for
Please take time to rate me
Bud
Posted on Oct 19, 2012
Hi I have a 2000 model KTM 520 not getting fuel to the Carby once I clean the carburettor does anyone have any ideas or know where I can download a good diagram would be a great help thank you
Hi, Tim always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Fuel valve/petcock not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing*
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn*
7. Fuel line from the fuel valve to the carburetor or fuel pump clogged, cracked, pinched, bent, broken, or missing.
8. Fuel pump not working*
9. Fuel line touching cylinder or head causing fuel to boil and vapor lock, repair by rerouting and wrapping line with convoluted tubing.
10. Carburetor inlet clogged.
11. Carburetor float or needle and seat stuck.
12. Carburetor not venting properly overflow line or bowl fitting clogged, pinched, or bent.
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Carburetor Set up 101 This is the Holy Grail/Bible on KTM carbs
Dirt Rider Magazine
2000 2007 KTM 250 400 450 525 SX EXC service repair manual pdf
http://www.partsfish.com/page/oem-parts-for-ktm
2001 KTM 400 520 SX MXC EXC RACING pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 23, 2016 | 2001 KTM SX 520 Racing
Scooter not getting gas to carb.
Silly question, but are you sure you are getting gas through the line? Could the line from the tank be plugged? How about the tank port?
Is there a fuel shutoff?
May 10, 2016 | Motorcycles
I have a stihl ts 410 that runs but after use it floods with fuel and then won't start till I have vented it
Sounds like a faulty fuel tank vent, creating a vacuum lock. Replace the vent
Feb 16, 2016 | Stihl Saws
Looking for fuel system diagram
Chances are its what is called the fuel pressure regulator is the problem.
These other systems have vents and valves and are disgined them selves .
The pressure regulator deals with the fuel injecters mainly back pressure feed back to the tank .
The vehicle will run OK but when you shut it off you smell gas vapor it has to get out .
Mar 26, 2015 | Cars & Trucks
Stihl 012 av fuel lines
The 2nd line might be a vapor return line back to the fuel tank? I've dealt more with repairing bigger saws more than smaller ones. You should go to a Stihl shop&take a look at chainsaws about the same size as yours&take off the air filter cover&look to see where the carburetor lines go.
Aug 01, 2014 | Stihl 011avt Brake Handle 009 010 011 012...
Need a diagram of fuel line system for a 311y chainsaw
http://www.doityourself.com/forum/outdoor-gasoline-electric-powered-equipment-small-engines/279941-stihl-chainsaw.html#b
  1. Stihl Chainsaw - DoItYourself.com Community Forums
    www.doityourself.com/forum/outdoor.../279941-stihl-chainsaw.html
    Oct 4, 2006 - I am in the process of rebuilding my Stihl chainsaw carb. I am having troubles identifying this Stihl model. The only sticker on the saw is 311Y.
Mar 22, 2014 | Stihl 311y
Bt 360 stihl
possibly a fueling issue, check fuel filter, tank vent and possibly replace carb diaphrams.
Feb 25, 2014 | Stihl 08s Ts 08 350 360 Bt 360 Clutch Hub...
Can you down load info and diagram or diagrams on
fuel pump is in the tank try to get most of gas out of tank then you need to unclip pressure line and return line and vent line unplug electric connector and remove tank there usually are no pictures for this if you need pictures you should hire it out
Aug 17, 2013 | 2002 Saturn L-Series
Stihl 44227 - TS360 AVSE Cylinder & Piston Assembly Logo
90 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
