Question about YouTube Videos
PAUL PINFOLD 30 YARDS WOLVERHAMTON
10 yards are what in feet?
none as yards is the larger dimension and is made up of feet
Mar 16, 2018 | Homework
How many cubic yards does it take to cover 1 inch deep, 3700 square feet?
Since we are trying to calculate the number of cubic yards, let's calculate everything in terms of yards.
Converting inches to yards, we have to divide by 36, since there are 36 inches in a yard.
1 ' = 1/36 yard
Converting square feet to square yards, we divide by 9, since there are 9 square feet in a square yard.
3700 square feet = 411 square yards
Calculating cubic yards, we multiply 411 square yards by 1/36 of a yard.
I get 11.42 cubic yards. So you are safe getting 12 cubic yards.
Good luck,
Paul
Aug 20, 2016 | Office Equipment & Supplies
Need to fill a 132ft long ditch that is 2 ft wide and 18in high with rock. how many yards do I need
We need to convert everything to a common unit, so let's convert the 18 inches into 1.5 feet.
Volume is length times width times height.
v= 132 x 2 x 1.5
v= 396 cubic feet
To convert to cubic yards, imagine a yard cube. It is 3 feet by 3 feet by 3 feet for a total of 27 cubic feet.
v1 = 396 cubic feet/27 cubic feet per yard
v1 = 14 2/3 cubic yards
So 15 cubic yards should do it.
Good luck.
Paul
Apr 27, 2016 | Office Equipment & Supplies
Area 40 ft long 4ft wide 5 inches deep how many sq yards needed
First step - convert everything to feet - 5" is 5/12 of a foot
40 x 4 x 5/12 = 66.6 cubic feet.
Since a cubic yard is 3 feet by 3 feet by 3 feet, there are 27 cubic feet in a cubic yard.
66.6 cubic feet / 27 cubic feet/cubic yard = 2.5 cubic yards.
Good luck.
Paul
Apr 15, 2016 | Office Equipment & Supplies
How many yards will it take to cover 30ft by 40 ft ,4inches deep
Do you mean how many cubic yards it would require to fill a volume occupied by an area of 30 ft by 40 ft by 4 ins deep? If this is what you mean then it would require 11.1 cubic yards. Hope this helps.Sorry I can't help with the cost.
Mar 26, 2015 | Pottery Barn Adair Floor Lamp, Bronze...
How many cubic yards are 2106 cubis feet
Imagine or draw a cubic yard. It has a length of 1 yard, a width of 1 yard, and a depth of 1 yard. Now each of these yards can be broken down into 3 feet, since there are 3 feet in a yard. Thus, a cubic yard has a length of 3 feet, a width of 3 feet, and a depth of 3 feet. We have 3 x 3 x 3 or 27 cubic feet in a cubic yard.
Next, take 2106 and divide by 27. The answer is 78 cubic yards.
Good luck.
Paul
Mar 14, 2015 | Office Equipment & Supplies
HAVE A PRONGHORN TASCO MOUNTED ON SAVAGE 22 BOLT. SIGHTS IN OKAY AT 10 YARDS AND THEN IS HIGH AT 25. IS THERE AN ADJUSTMENT INTERNALLY IN SCOPE TO FIX THIS?
No, this is not a scope issue. The scope is raised above the centerline of the barrel, thus at 10 yards, the barrell is actually slightly raised in relation to the centerline of the scope in order to hit your point of aim. Since the front of the barrel is slightly inclined, at 25 yards the bullet is still rising in relation to the scope alignment. Backing up to 50 yards you will begin to see the bullet start to drop back down, at 100 yards it may drop as much as 8-10 inches, and at 200 yards, it may drop as much as 52 inches. This is assuming that you are shooting a standard velocity .22 long rifle cartridge (1050 feet per second or so).
Sep 10, 2010 | Tasco Pronghorn 3-9x50mm 30/30 Riflescope...
Can my bushnell yardage pro rangefinder be calibrated. It is 4 yards off at 30 yards and 7 yards off at 40 yards. So on and so forth
I would send this unit in for repair to have it inspected you can reach their customer service at 800-423-3537 option 1.
Oct 04, 2009 | Bushnell Yardage Pro Tour Rangefinder
I'm using a red dot scope on a mossburg turkey gun with a choke. I'm using the 3'' heavy tungston loads for longer distance shots. What distance should i zero in the scope at? 20 yards? 30 yards? 40 yards?...
I set my sights for 30 yards.40 yards is a long shot because you always aim for the head when hunting turkeys.Good luck with the Mossberg.I traded mine for a Remington.Still got a Mossy for a "loaner" or a backup gun for a client.The 3.5 magnums are simply too punishing to the shooter.
Mar 08, 2009 | Optics
YouTube Videos Logo
21 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
