Question about Baby Gear
Missing metal stud - fine thread and base bracket nut for murano cot/bed
I have to metal studs - fine thread missing and a base bracket nut for a murano cot/bed
SOURCE: lost instructions to turn cot into toddler bed
hi dont know if this is any help but going from memory with my own little lads cot bed do you still have 2 side pieces the lenght of the cot well they replace the side rails and also both head ends of the cot divide in two to form a smaller headboard kind of thing....hope that is of help
mags
Posted on Jan 13, 2009
SOURCE: Assembly Instructions Durham Cot Bed
Have attached a copy of my instructions
Posted on May 10, 2009
SOURCE: Mamas and Papas Murano cot bed problem
fully dismatle the cot, keep all the bits.. Take the two slatted sides to bits and put the base pieces of wood from these to one side.
pull the headboard and footboard (is that whats its called) apart take the feet from the footboard and add to the headboard (they are now the sole head and foot boards) screw the 4 nuts with blanking plates to the top 4 holes on the new head and footboards
take the two long slatted size bases and screw them to the lower holes on the head and footboard put the base brackets (L shapped screws) into the corners put the cot base onto the L shaped screws done
Posted on Aug 03, 2009
SOURCE: assembling instructions for cot bed
I'm selling a salisbury cot bed and would like to download a copy of the instruction manual which I no longer have - also need a couple of fixings to be replaced, where I can get some. Thanks.
Posted on Feb 01, 2010
SOURCE: I have a mamas and papas cot i brought in 2002 and
Hi i have a cot with no fixtures only the metal bars i have lost the nuts and bolts the make of the cot is Mamas and Papas SONIA EN 716-1:1995 i have been intouch with Mamas and Papas and they say that they cannot help. This cot was lent to us and i am in big trouble
Posted on Mar 22, 2011
The threaded sleeves for the studs that hold the guide bar are stripped. What can I do to repair them?
remove bad studs with stud extractor and replace with new ones ?? or maybe normal bolts ?? (if in engine housing )
or in a bind ive even rethreaded them to fine thread (assuming course was old thread) with a die and used std fine nuts on them as well .
if studs go in plastic case/frame then case needs to be disassembled and then studs press out other direction
Mar 16, 2015 | Garden
How do I remove the studs on the base of soft bodied pram to replace wooden base which got damp
If the attachments are press studs then drill out the centre of the studs to get them apart. replace using small bolts and nuts or use new studs again from hardware shop
Nov 10, 2014 | Baby Gear
Chevy camao
Not necessary to remove axles. Remove drum or rotor, hammer through the damaged stud, has room to fall out behind axle flange. Insert new stud through opening, A stud installer is preferred at this point, however, you can also use a couple of stacked washers and a lug nut. grease the washers, place them over the stud, grease the stud threads and then thread on the lug nut. With a socket wrench ,crank the stud down. The splines on the stud will bite in , keep turning until stud base meets axle flange. A new lug nut may be required , the one you use as an install tool may get damaged.
Jan 08, 2014 | 1998 Chevrolet Camaro
Thermostat broken stud
You can replace it. There are several types of screw extractors out there. They usually come with a drill bit for the correct size extractor. You will need to find out what size stud it is. Once you have determined that chose the appropriate size drill bit and extractor. Lowes or home depot carry them. Drill into the center of the broken stud. Be careful not to drill too deep as you might damage the thermostat housing. Once you have drill into the stud use the extractor to remove the broken stud. Napa auto parts or autozone should carry the stud size and length that you need. Purchase a stud and 2 plain nuts that match the thread of the stud. The nuts will be used to install the stud. Thread The stud into the thermostat housing. Once it is tight by hand stop. Thread the first plain nut onto the stud far enough so that you can get the second nut onto the stud and have a thread or two sticking out of the second nut. Once the two nuts are on the stud hold the first nut with a wrench and tighten the second nut tight against it. This will allow you to finish installing the stud. Once the nuts are tightened together, use a wrench (on the second nut only) to run the stud down into the thermostat housing. Do not overtighten the stud as you may crack the housing. Run the stud down into the housing unit the stud is the same height as the existing stud. Then use a wrench to hold the second nut and loosen the fist nut away from the second nut. Remove both nuts from the stud. You stud is now installed and you can reinstall the thermostat. If you have any questions you can email me at dplumb1@me.com Good luck
Oct 25, 2012 | 1997 Nissan Maxima
How can I fix cross threaded wheel screws?
Go to the auto parts store and borrow a nutcracker. Attach the nutcracker to the stuck nut. Tighten the nutcracker with a rachet wrench until the cracks completely in half. Now you can remove the wheel. Buy a new wheel stud and lug nut. Your lug nut will be pressed into a metal piece. Remove this piece and either 1) support the metal piece, put a good amount of penetrating oil on both sides of the bad lug nut and tap firmly with a large hammer. Let this sit for 5-10 minutes so that the oil can penetrate the stud. Now pound out the old lug nut with a large hammer. If it will not budge, then you can try heating the stud with a torch until it is quite hot and then hit the stud progressivly harder until it comes out. Now insert the new stud and pound it in until it stops moving. Last, before you reassemble, put the lug not on the new stud and tighten it real good to make sure that the stud is comletely seated. 2) the other option is to take the metal piece to the parts store and let them remove the stud and press a new stud for you.
Jun 24, 2012 | 2003 Honda Accord
Mamas and Papas Murano Cot/Bed with missing Parts
I have a mamas and papas murano cotbed and there is a slat missing, does anyone know of a solution?
thanks
Apr 07, 2012 | Mamas and Papas Baby Gear
97 Buick Lesabre-Am I crazy or do you have to unhook the engine mount to replace serpentine belt,I hope im just missing something. Thanks for any help. Don
Not the whole mount! Raise the car, remove passenger front wheel. Remove two clips that hold splash guard that is in front of the lower part of that engine mount. You'll then see the lower stud with a nut on it. Remove that nut, remove stud with a socket, then remove the spacer that was around stud between bracket and engine. That opens a gap to allow the belt to go on.
Dec 06, 2009 | 1997 Buick LeSabre
How to remove bolt and loge nut from car wheel that is striped
If you have a stripped lug nut on your vechicle, the best thing is to take the vehicle to a tire shop and have them remove the nut. You can drive missing one nut tempoarily. They have universal tools for removing wheel locks and this will work for this application. You will need a new nut.
If you have a stripped wheel stud, these are available at your local parts store. To remove the stud you will need a small sledge hammer. when the wheel and brake drum/rotor is off, the stud should be exposed. There should be a hole in the backing plate of the axle and this is where the stud needs to be lined up with. Hammer the stud out through the hole. Next, replace with the new stud. To seat the stud on the splined area you need to press the stud into place. Using a number of flat wahers, place them on the threaded part of the stud until only 5 threads are showing. Turn on the new nut and tighten the nut until the stud is pulled into place. You may need to remove the nut and add more washers to seat the stud. Hope this helps.
Oct 22, 2009 | 2007 Ford Edge SEL Plus
May 18, 2009 | Baby Gear
Wheel studs or bolts
Hello Miguel Thank you for using FixYa.com my name is David I hope this Helps you out.
Studs often get damaged from overtightening or from cross threading a nut on the threads. A damaged stud is replaced by unscrewing it from the part and installing a new one of the exact same size.
Stud replacement can be difficult because the stud has often been in place for a long period of time. There has been constant heating and cooling, corrosion, and rust buildup between the stud threads and the internal threads of the part. These factors combine to make some studs very difficult to remove.
The first step in stud removal is to use penetrating fluid to remove the corrosion to free the stud from its mating threads. Soak the area of the threads with penetrating fluid. Allowing the fluid to soak into the threads overnight will make it easier to remove the stud.
Before removing the old stud, measure the distance it sticks up from the surface. This measurement will be needed later when installing the new stud. Use a 6-inch scale to measure from the part surface to the top of the stud. Write the measurement down so it can be referred to later.
A stud remove is used to remove studs. It is installed over the stud. The jaws on the stud remover grip the outside of the stud. A wrench fits on the stud remover and allows the technician to rotate the stud in a counterclockwise direction to remove the stud.
If a stud remover is not available, a stud can be removed with two nuts. Locate two nuts that are the correct thread size. To thread onto the stud. Start one nut and thread it all the way down to the bottom of the stud. This nut will be the drive nut. Start another nut and thread it down until it contacts the first nut. This is called the jam nut.
Put a wrench on the bottom drive nut and hold it in place. Put another wrench on the jam nut and tighten, or "jam" it against the drive nut. The jam nut will now hold the drive nut in position on the stud.
Now put an open-end wrench on the bottom drive nut. Turn the nut in a counterclockwise direction. Turning the nut in this direction causes it to want to unscrew the stud. Instead the forces cause the stud to unscrew.
When the old stud is out, inspect the internal thread. If it appears rusty or damaged, clean up the thread by running the correct size tap through the threads as previously explained. Compare the new stud with the old one. The studs should be exactly the same thread size and the same length.
Check the vehicle's service manual to determine if the threads of the new stud should be coated. If the stud should be locked in place and not easily removed, you may need to use a threadlocking compound or threadsealing compound. Threadlocking compounds are on studs and other fasteners when vibration might cause them to unscrew. Thread sealants are used when a stud extends where liquids, such as oil or coolant, could get on the fastener.
Antiseize compound is used on the stud threads to prevent the stud from reacting with the metal on the internal threads. If this happens, the stud could stick or seize. Antiseize compound prevents this reaction and makes the stud easier to remove the next time.
After the new stud is properly coated, it can be installed. Start the stud by hand, making sure it enters the threads securely. Turn the stud in as far as possible by hand before using any tools. Then use two nuts as described earlier to drive the stud into the part. Use the depth measurement made on the old stud to be sure it is driven in the correct depth.
upper_left.gif grey_line.gif upper_right.gif grey_line.gif Look for More Parts A B C D E F G H I
J K L M N O P Q R
S T U V W X Y Z grey_line.gif lower_left.gif grey_line.gif lower_right.gif Related Parts: grey_line.gif 0900823d80050bfd.gif Wheel Nut
Nov 06, 2008 | 2005 Chrysler PT Cruiser
Baby Gear Logo
74 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
