Question about Freezers
Fv245 red warning light on
Green power light not on tho power is there
Power is on but don't run
Is the red light flashing if so count the #of flashes it shows consecutively.then Google that #of flashes on that model you will get your answers. If just solid red you may have an issue in the board or compressor
Aug 11, 2014 | Haier Freezers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
The red warning light (exclamation Mark) is on?
check the condensor fan if it has one
Apr 10, 2010 | Freezers
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
New fan light running continuosly
lets see if i can help you out here, okay . Red is your hot power wire, Green is the ground which is screwed to mounting plate, black is negative, meaning no power.... connect your wires by color Red to Red , Black to Black , And if there is a green coming from the ceiling connect to mounting plate of fixture or vise versa. Remember to use eletrical scew caps, on all connections and do not leave any wires uncovered. Basically all your doing is a seperation of a wire from wires as you seperate a wire cap it off. then move to the next set and do the same. red to red black to black green to mounting plate . YOU WIL NOT BLOW ANYTHING UP IF THERE IS A WRONG CONNECTION, if all wires are of color follow these steps, if no color switch one wire try switch and vise versa YOU can do it
Jun 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Samsung water filter rs21 dcns
Hold down the "ice type" and "child lock" buttons (bottom button on the left and the right) together for about three seconds. The light will change back to green.
Aug 06, 2008 | Freezers
Servis fridge freezer mo330al lights
Hi there
  • Green = Ready (Power ON)
  • Amber = Super Speed Freeze
  • Red = Warning overheating or fault.
Hope this helps
Thanks J
Jan 04, 2008 | Freezers
Freezers Logo
26 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
