Question about Jenn-Air JGC8536 Gas Cooktop
I disassemble to clean and now it won't light
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
Tip
KithenAid Gas Cooktop Igniter Clicking after cleaning.
I had this problem and the solution is quite simple. Remove the control knobs and shoot a good squirt of WD-40 directly down the center of the exposed control shaft. The WD-40 will penetrate the switch located at the base of the shaft and displace the water from inside the switch, which is causing the intermittant operation or clicking of the ignition. I actually disassembled my cook top to learn this fix, but don't take yours apart it's waaay too much trouble.
on Jan 11, 2011 | Cooktops
How to adjust a gas hob burner that is noisy and erratic?
First disassemble and clean then see if adjustment is still necessary.
Aug 26, 2014 | Cooktops
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
Gas burner dial won't turn
maybe it needs to be cleaned, use some dawn and water on a rag and rub around the dail .
Sep 03, 2012 | Maytag MGT8885XS - GeminiR Double Oven...
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
I have the star burner model, w/ extra-low simmer. The center burner will not light at all by itself. The right rear burner will self-ignite if you turn it to low, and then slowly rotate the knob clockwise...
Center burner won't light: If there is a bright spark (check all ignitor points at night with the lights out and look for consistent brightness of the sparks) then it's likely that the burner slots are dirty or the air/gas mix is wrong. If you can light with a match, but the spark won't light, then go for cleaning the entire burner assembly thoroughly with a brass bristle brush (available at most automotive stores). The proper air/gas mix has to flow over the spark to ignite. Weak spark, improper air/gas or misdirected gas flow that misses the spark can all cause this issue.
RR burner lights only on low setting. Again, check the air gas mix and clean all parts. Something like a small spider web inside the air mix chamber (area between the orifice and the burner can cause this and is difficult to see. Disassemble, clean thoroughly, reassemble and test. Extra low simmer burners (two on the left side) use their own control module with electric gas valves and variable electric control switches. The burner works on low, so these are not likely the problem.
Most folks want to find a bad part, and that can happen, but stove tops get dirty and cleaning usually helps. If not, you have a clean top to work on.
The indicator lens and/or the retainer are either broken or the retainer is missing. It's best to replace these as they are not expensive. When the top is off while cleaning is an perfect time to replace the lens.
Mar 30, 2017 | Thermador 37 in. SGSX365 Gas Cooktop
I have a DSC CT-365 cooktop that won't light the center burner. Spark is fine. no holes clogged in the burner unit. It appears that there is a small orifice off of the main center hole. I assume this...
TRY TO USE 1ST THE VACCIUM TO **** THE SMALL PC THAT U SEE.USE ALSO SMALL TIP NIDDLE TO PUT IN HOLE TO REMOVE THE DIRT THEN VACCIUM AGAIN AND AGAIN
May 22, 2009 | Cooktops
Burners not lighting
I had the same issue and replaced the spark module myself, lots of wires and you have to make sure to label them before removal to be able to hook them back up correctly. To get to the module you need to unscrew all burners, no need to take the cover plate under the knobs. Burners remove by unscrewing center, brass nut. OEM spark module is VIKING RANGE #PA020021 U-67205-21. Go
od Luck
Apr 18, 2007 | Viking 37 in. VGSU161 Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop Logo
22 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
