Installing a Washer in basement
Installing my Washer in basement, the drain comes down the wall off of the main sewer line and stops half way down the wall, has a threaded fitting, and was trying to figure out if the washer connects to the with a pipe barb and clamp the drain hose to that, I have never seen a hook up like this before, got me thinking about it, don't know by looking at it, and don't know if the washer pump will lift that far?
  • karlaandpaul Nov 08, 2008
    I have the same issue. The question is really about how far the washer can lift the water. I'd still want it to drop into the sewer line, as I don't want to have a sewer backup that drains back into the washer! Do I install some sort of backflow device where the washer would push it open?
  • 94 Answers
The top of the drain pipe that the washing machine drains in to should be about 3 feet off the ground. If the sewer pipe is higher than that you can either get a longer hose, or drain it into a sump with a sump pump that pumps it into the sewer pipe. If you don't have a sump, first try the longer hose and make sure it drains to a point higher than the sewer pipe (that would be the easiest) or cut a hole in your floor and put in a sump and sump pump (the most difficult).
Posted on Oct 08, 2007
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
You will need a non return valve so the dirty water does non go back into the machine ?? if you are able to rig up a pipe you can see how much your machine can lift the water and how high
Posted on Dec 29, 2013
RC 92+ Upflow Condensing Tappan Furance: we have sewer smell in basement that is strongest in furnace room. No floor drain. We have a pvc pipe with condensation hose from furnace in it. The trap continues...
the switch is a service or emergency switch if the condensation hose / line is not a sealed connection and the trap is empty the sewer smell will be constant either make it a sealed connection or close off the trap and reroute the condensation line --during heat season not condensation so heat will cause water in to evaporate
May 17, 2017 | Heating & Cooling
Main sewet line on 2 story hom
Well the main will be in the basement first snake the drain that's pluged but would use a plunger first chances are your haveing a problem in a bathroom drain if so remove the plug get something thin chances are full of hair
Jul 07, 2013 | Plumbing
The water drains out of my Maytag Atlantis washer, but water backs up in the drain pipe. I have had a plumber run a snake and cleared the drain, but water still backs up. Is there anything that coul
The wall box outlet probably is about 1-1/2 in. in diameter. If it was snaked clear then there may be blockage in the main sewer line. In my case, there is a 90 degree bend that gets blocked periodically and causes the washing machine discharge to back up
Feb 08, 2013 | Washing Machines
I need to put a washing machine in my basement where there is no drain
Home Depot has such a unit as does Several different brands...ask for under sink utility pump unit.
Mar 26, 2012 | Plumbing
Our basement floor has been dug up including the floor drain. How do you go about replacing this. our contractor wants to put crushed rock for the water to drain into the drain and concrete over this.this...
He sounds about half right, but I would want to know if the water is in the basement all the time? or does it come through the slab? The walls? Is there any water? You don't need forms of any kind in a basement or patching a big hole, the hole is the form, fill it up and level it off. He might be concerned about a dry trap if there is one on the floor drain. Depends on where it drains to. Sewer? It is code now for floor drains to have trap primers on them so they stay full. No gas. Hope this helps.
Jul 02, 2010 | Plumbing
Fowl odor (sewer like) when washer is running.
Can you see the washer drain line,or is it inside the wall.
You should never smell sewer, I would find a good plumber,or a handy man that knows plumbing, and have him open the wall (if needed)
and install p-trap where the washer is located, at about floor level.
From what you said I think that someone ran a straight line to the cellar and installed the p-trap down there, also have them check the line to see if the line has been connected to a breather line, if not have him install a breather line right there with a one way breather valve inside the wall. The buildup and mildew around the compartment is due to the way it was made by the MFG of the machine, most 1000.00 front washers have a very poor design with this. All you can do is to remove it and clean it with bleach once a month. If you live in an nice area,but not very rich, the cost to do the drain should be around or under 350.00. I hope you get this squared away with no problems.
Mar 21, 2009 | Kenmore Washing Machines
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Sewer backup
Do not put that in the drain in the basement. Use a sewer snake cleaner to fix the problem. Drain cleaner is very corrosive and can burn your skin. If it doesn't work, you will have to work around the drain cleaner.
Feb 08, 2009 | GE Profile Prodigy WPSE4200A
Help! My basement washer
hmmm..sounds like you may be suffering from back pressure problems. here's what you try first
take about a 5 gallon bucket, and fill it up with water. then let it flow down the drain hole, and then quickly refill the bucket. you are looking for what happens when you have about 25 gallons in 2 minutes going into that hole. If it doesn't go right through, then you might want to have that pipe cored out(in an older home, that's not unusual).
try that first.
Feb 17, 2008 | Washing Machines
Washing Machines Logo
1,743 people viewed this question
Top Washing Machines Experts
