Question about Epson Expression Premium XP-600 Small-in-One Inkjet Printer
0xEA set-up error 0xEA
What does an Epson XP 600 error code OxE3 mean?
Check this previous thread....
http://www.fixya.com/support/t18998484-epson_expression_xp_600_error_code_0xea
Epson expression xp 600 error code 0xEA when setting up
Oct 19, 2016 | Epson Office Equipment & Supplies
What does 0xEA error indicate?
Do you know how to check ' what is printing'? If you do, please check and delete all unwanted list on the printing queue. Switch it off completely and disconnect all the cables leave it for a few minutes and reconnect the cables and switch on. It should work.
Nov 07, 2015 | Epson Expression Premium XP-610...
Error code 0xEA
Epson WorkForce WF 3640 mechanical issue during initial setup errors 0xF1...
says:
Print Error Code0xE3 and 0xEA
We have seen some success with this issue by following these instructions. Please try this procedure one more time using the instructions below.
  1. Turn the printer off, then disconnect the power and the interface cable. Open the cover and check for any torn or jammed paper and remove it.
  2. Reconnect the power cable and turn the printer back on.
  3. Press the Copy button and see if the unit responds.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the issue persists, the hardware itself is malfunctioning and will require service
Oct 09, 2015 | Epson WorkForce WF-7620 Wireless Color...
Tried answer to question but printer still the same.
Dear
If the error at PC reload fresh OS. if at printer clean the DIMM (RAM) of the printer.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
What's wrong with printer set up when printer says 'printer error Turn off power and on again. Error Code 0xEA!!
Dear
The error mean the carriage assembly is jammed.ensure there is no material, tapes, or anything else stucked inside and the cartridges are seated in properly. If reseating cartridges does not help, turn the printer off, take out the cartridges and inspect them carefully to see if any material is left over on the cartridges.
If no material is found, reseat the cartridges and check again. If you still receive the 0xea error then contact the retailer you purchased the printer from for a replacement.
Thanks.
Sep 26, 2014 | Epson WorkForce WF-3640 Wireless Color...
Error code c43
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0."
Jan 14, 2014 | Toshiba Office Equipment & Supplies
I had the same problem today. I opened the printer below the scan bed, where you install the ink cartridges and there was a piece of packaging material that got left in that while I unpacked. I removed that and the 0XEA error was gone. I was sure the problem was nothing to do with the cartridge installation as it was the initial setup of the printer and cartridge installation was the next step based on the user guide. I was getting this error on initialization after setting the region, date and time.
Jul 24, 2013 | Epson Expression Premium XP-600...
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
Epson Expression Premium XP-600 Small-in-One Inkjet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
