Question about Timex T5G341 Sports Radio Control Watch
How to set time and date after replacing battery
Is there any way that I can set my Seiko perpetual calendar watch at home?
What a great watch! It has a super-fine piezo-electronic motor to move the date wheel! Very cool. Its quite a show to go through the date/leap-year check, and then observe the watch catch back up to the correct time afterwards. Battery lasts ~five years.
I downloaded the manual (your model number on watch back) after a short search online (beware of trojans/viruses).
Setting after a battery replacement requires shorting certain pins inside the watch to set the leap-year, and date. The back unscrews, and may require the special watch-wrench, available online. I unscrewed mine VERY CAREFULLY with fine pliers, confirming that I was doing this in a clean, dust-free location. The instructions are quite specific, must be followed carefully to set up correctly. Have a fine wire jumper to set the leap-year. I learned this because I did not want to pay an inexperienced jeweler $100 to replace the battery.
Oct 13, 2014 | Seiko Watches
I cant set the date, because I got the battery replaced and I the date is two days late
Use the manual to set the correct time zone, time and date. Manual is available on the Casio worldwide website>support>manual>watches.
Have the module number at hand: you will enter it to find the manual. The module number is a 3 digit or 4 digit number on the back of the watch.
Nov 09, 2013 | Casio G-Shock G 300 G 301B 1ADR Watch
I replaced the battery. The watch started time from Jan. 1
You have to set the year, the month and the date. Then you set the time zone. After that you can set the local time. You may also have to set the Daylight Savings Time.
The watch has a built in calendar that may run from let's say January first 2000 to the year 2070 (just a guess). If you set the calendar correctly you do not have to adjust the date when a month has 30 days, or when it is a leap year.
Sep 27, 2013 | Casio GW330A G Shock Solar Atomic Watch
Replaced battery but unable to reset watch to correct time, etc??? says on sticker on back of battery, "short pads to reset" short what pads??
there is reset button beside the battery or you have another option is to push all the buttons of your watch to reset and you can now set the time, date and other that had to be set manually..
Jul 08, 2011 | Watches
I replaced the battery in my casio wave ceptor watch and the time and date displayed now is incorrect. How do I set the proper time, or will the watch access the satellite and set itself?
Hello Wifferdil38,
I believe that I've located a manual for your watch which will help you to re-set the time and date. Please click on the following link:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2556.pdf
Please let me know if you need anything further.
--Sandy
Apr 13, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
The date and time are changing by themselves
I had the problem with locking on chrono function. Then I decide to replace battery, after replacement watches become crazy, hands were moving all the time, it was impossible to stop it. I remove the battery and leave watches on the table for 5-6 days, then install the battery again. No problem any more, all functions are available. May be you have the same kind of problem. Good luck!
Jul 02, 2010 | Tissot T-Touch T33759851
Setting watch after battery replacement unable to set watch
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Make it as big as you need.
Hope this tip helps
R/
David
Dec 26, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
CY2068 HOW DO YOU CHANGE DATE AND DAY
Pull the crown half way out to set the date. To set the day, keep advancing the time - 24 hours for each day. The day will change at midnight each 24 hours. It's a time consuming but one-time-only effort as long as the battery is good.
Sep 25, 2009 | Callaway Golf Sport Series Chronograph...
Replace battery on a casio gshock.
good morning ! you need to short the reset poin on the bord of your watch after that you see the digit will apear on LCD then start to set the time use the setting button to set the time date and day ! thank you ! god bless !
Dec 16, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Dec 01, 2007 | Watches
Timex T5G341 Sports Radio Control Watch Logo
32 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
