Question about HP Laserjet CM2320nf All-In-One Color Printer
Erro 50.2 para laserjet cm2320
Como resolver
SOURCE: Laserjet cm2320 fxi mfp has scanner error 5
when Printing from my HP 2320 there is a slight blue streak on the Right side of the page
Posted on Jul 07, 2009
walesarumi
  • 6993 Answers
SOURCE: Como resolver o problema da
in the case of error, the first thing to do is to reset the printer. Follow the below steps to reset the printer:
Without turning off the product, disconnect the USB cable from the rear of the product.
Remove the cartridges from the product.
Wait for the 'Insert Cartridges ' message to display on the control panel.
Disconnect the power cord from the back of the product.
Wait 60 seconds.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Reinsert the cartridges, and then close any open doors on the product.
If you receive a prompt to print a calibration page, do so.
Reconnect the USB cable to the rear of the product, and then try printing again.
Or, completely uninstall the printer from the system, re-install it, then try again. I hope you have the printer's software.
First, go to Start > control panel > printers.
Right click on each printer icon you see, scroll to delete and click. Make sure all the printer there are deleted.
Go back to control panel, click on program and features (for windows vista/7) or Add/Remove Programs (win xp).
Disconnect the printer cord from the computer.
Uninstall every driver/software that is associated with the printer.
Restart your computer.
After your computer has been restarted, install the printer driver afresh and connect the printer to the computer.
If this doesn't solve the problem, you will have to download Hp diagnostic utility on your your computer,install is on your computer and it will help to detect and solve the problem.
Visit the hp link below, read all the information on the page and download the diagnostic tool from the page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02114788&tmp_task=solveCategory&lc=en&dlc=&cc=us&product=441125
Good luck.
Posted on Jun 29, 2011
vinay229229
  • 1121 Answers
SOURCE: modelo da impressora,HP laserJet M1120
little bit I under stood your language, there is scanner error 22, remove flat bed glass, remove scan head, check mechanism observe any breakage, replace it mechanism, if no replace entire scanner head..see the test shot.
Posted on Sep 10, 2011
SOURCE: HP COLOR LASERJET CM2320 MFP "READY 2 DOWNLOAD"
ready 2 download
Posted on Oct 18, 2012
SOURCE: Tengo problemas con un Multifuncional
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Posted on Jul 25, 2013
Fwlink linkid 106440
Primeiro em Ingles e depois em Portugues:
Dear Eustaquio, in order to try to solve your problem, we need you to provide us with a little bit more information, like:
1) What is the version of your Windows OS?
2) What is the version of your Internet Explorer?
3) Did the problem started after you proceed with any kind of updates? Even automatic Windows Updates?
4) Please, provide us any other information you may find important to let us understand how the problem first appeared.
Agora em Portugues:
Caro Eustaquio, para que possamos tentar ajudar a resolver este problema, necessitaremos que voce nos forneca algumas informacoes, tais como:
1) Qual e a versao do seu Windows?
2) Qual e a versao do seu Internet Explorer?
3) O problema surgiu depois que voce fez algum update no Windows ou no Internet Explorer? Ou depois de alguma atualizacao automatica do Windows?
4) Por favor, de-nos quaisquer outros detalhes que voce ache relevante para que entendamos como o problema apareceu originalmente.
Esperamos sua resposta para poder tentar ajuda-lo!
Atenciosamente,
Regards,
Miguel. L. Martins
(OBS.: estou escrevendo sem cedilha e sem acentuacao porque este sistema do Fixya nao permite caracteres Unicode que nao sejam os do Ingles - qualquer acento impede a mensagem de ser enviada)
Oct 30, 2013 | Computers & Internet
Como resolver o erro da cp5525 laserjet color
please would write English so can i understand you
i can help you do not worry , just go to Google translator covert your message to English , then i will reply you with propor answer
Hope help you
Sep 23, 2013 | HP Color LaserJet Enterprise CP5525xh...
Riso RZ200ep. como resolver o erro codigo A - 06 -403
Jul 08, 2012 | Office Equipment & Supplies
Quando ligo a maquina dsm715 ela informa logo o codigo sc322. como faco para resolver?
Independente do modelo ser Dsm715 ou Dsm745 esse codigo corresponde a um erro na Unidade de Laser, mais precisamente com o sincronismo.
A primeira coisa a verificar nestes casos é se a Unidade de Laser está suja. Por vezes cai toner para o Laser e provoca estes codigos.
Se tiveres conhecimento tecnico saberás chegar á unidade de Laser. Se não tens esse conhecimento aconcelho a não mexeres (chama alguem que o saiba fazer).
Na minha opinião este deve ser o primeiro passo a dar. Deves fazer uma limpeza na Unidade de Laser.
Se não resultar replica para mim ou volta a colocar a questão no Fixya. Existem otros factores que podem provocar este codigo.
Fica bem!
Apr 25, 2011 | Gestetner DSm745 Black and White Copier
Boa noite estou descarregando o aparelho mas esta dando erro na transmissa digite enter, mas nao sai disto preciso descarregar ja troquei a bateria qual a solucao?:
Boa noite
Eu tenho um igual e de vez em quando acontece-me o mesmo, como consigo resolver a situa??o, ? precionar a ficha RJ enquanto o PDT est? a transmitir para o PC.
Se pretender tocar mais ideias o meu mail:arlindopolicarpo@hotmail.com
Jan 16, 2011 | Symbol PDT 3100
COMO FAÇO PARA RESOLVER ESSE ERRO 0XC05D0281
i have this error 0xc05d0281 em hp photosmart 3313 all-in-one.
what can i do?
Sep 23, 2010 | Office Equipment & Supplies
NAO CONSIGO USAR MAIS O CONTROLE REMOTO, COM ISSO NAO CONSIGO FINALIZAR O DISCO......QUANDO TENTO USAR O CONTROLE APARECE NO DISPLAY " CHECK REMOTE ". E NAO SAI DESSA.
Há algum tempo o meu Gravador de DVD de mesa Panasonic DMR-E55PL-S vinha apresentando a seguinte mensagem de erro sempre que eu clicava qualquer comando através do controle remoto: CHK REMOTE2 Havia entrado em contato com o técnico da autorizada Panasonic de Niterói e ele ficou devendo-me uma solução. Como possuo outros 3 gravadores de mesa (2 Pioneer e 1 Samsung R121), apesar da contrariedade, não esquentei muito a mufa. Hoje, porém, encasquetei, e resolvi tentar, mais uma vez, resolver a má função. Após "ene" tentativas malogradas pintou o insight: - "Cacildas! Se eu faço tanta pesquisa para dirimir as dúvidas dos companheiros, por que não o faço também, para mim"? Assim, digitei no "gluglu": CHK REMOTE2 Panasonic Entre outras dicas, saquei esta: Question: - "Whenever I press any button on my remote control, I get this error message on the front panel display - CHK REMOTE2" Answer: - "Just hold ENTER and press the number indicated on the display for a few seconds, and it will fix the issue". Basta clicar ENTER e pressionar o numero indicado no display do painel frontal do gravador por alguns segundos - isto resolverá o problema. (Clicar ENTER e pressionar o número 2 no controle remoto). Tal dica serviu para o meu DMR-E55PL-S como também para o DMR-E85HS - do **** "flashcode" - devendo servir para outros modelos Panasonic da mesma linha. Soçarba... Mr. Walker
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
Scanner visioneer 4800
go on this site and download it:
http://support.visioneer.com/UK/products/home/EOL/4800/downloads.asp
Jul 17, 2008 | Office Equipment & Supplies
HP Laserjet CM2320nf All-In-One Color Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
