Question about Honeywell R7284U1004 universal electronic digital oil primary
Hard lockout When I tried to reset the furnace lights in the garage started flickering when trying to start up
    Top Expert:
  • Honeywell Master
  • 42,882 Answers
The garage lights and the furnace could be on the same circuit. The flickering is due to the heavy startup load of the furnace.
Posted on Nov 21, 2013
I have a SA Series 80 Furnace and I get a alternating green and red light meaning a 1 hour lockout. What causes the 1 hour lockout?
It tried to lite 3 times unsuccessfully then it will lock out ,may need flame rod cleaned. Try YouTube for video about problem.
Dec 22, 2017 | Heating & Cooling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Furnace lockout
Change the flame sensor, check the connections on the sensor are tight , check pressure switch , check air filter is clean .
Jul 05, 2017 | Heating & Cooling
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
I have an older sterling gas furnace hung from the garage ceiling that cuts out intermittently . It does not trip the breaker but often if I reset the breaker at the fuse panel box it will start up.
The heater is going into "lockout"... it should be flashing a code on the ignition control that will tell you why it went into the lockout condition...
My guess would be that the high limit switch is bad or going bad and it is cutting out when it shouldn't be... or the flame sensor is loosing contact and cutting the burner off...
You could try to clean off the flame rod with a soft cloth...
heatman101
Jan 18, 2011 | Sterling RF30 Natural Gas Garage Heater
This is a Dayton gas furnace model GF9S120D20UP11H and i am getting a flash code of ignition lockout due to recycles. how do i fix it? i have taken all the filters out and washed them and also checked...
Usually a lockout code means it tryed so many times and then it locks out or stops. First, when a furnace is locked out you have to kill the power to the furnace to reset the lockout. I don't know this furnace but there are manual resets around the burner called flame rollout switches that have buttons in the middle that have to be pushed back in. Also the power vent has to come on when the furnace gets the signal from the thermostat. This is proven by a flow switch with a rubber hose on it. The next step is a 30 sec. purge, then the igniter glows or sparks and then the main burner comes on.
The other switches are hi limit on the front wall of the heat exchanger. That might get you started. If you have anymore questions rspiak1@cogeco.ca
Jan 13, 2011 | Dayton Gas Furnace Heater
I just turn off the gas and now how do I re start the airco furnace
The gas lines will as you know have air in them. AFter trying to start several times the heater will lockout.. I would suggest turning power off to unit and turning back on to reset.. Try several times until gas finally gets to unit... did this work ?
Sep 02, 2010 | Heating & Cooling
Sterling garage heater wont always light.
The flame sensor is dirty - have the unit serviced. Modern furnaces require regular maintenance!
Mar 10, 2009 | Sterling RF30 Natural Gas Garage Heater
Honeywell R7284U1004 universal electronic digital oil primary Logo
236 people viewed this question
Top Honeywell Televison & Video Experts
mikemail1
Ron Durham
Are you a Honeywell Televison and Video Expert? Answer questions, earn points and help others
