Question about Biddie Buddies Pink Small Animal Hideaway Tunnel Cage Attachment Tube for Hamsters Mice & Gerbils
I would like to purchase the Hideaway tunnel cage attachment tube for biddie buddies cage, but can not find a source. Is it still available/would others work
Model number LD 5MC-C
The pump you are looking for is not made anymore. The Air Switch version is still available.
You will need the replacement pump, an air button and some air tubing
to make the new system work for you.
You can find this and bathpartsplus,com under their bath pump section.
US Parts Center
Jul 02, 2014 | Balboa HydroAir Magna Series Spa Eyeball...
How do lobster traps work?
Lobster traps work by baiting the lobster into a cage that has an opening which is shaped like a tapered tunnel, so that it's easy for the lobster to get into the cage, but hard to get out.
Mar 09, 2011 | YouTube Computers & Internet
How to put together a fisher price play gym for babies
There are several different ways to set this sytem up, all based on your baby's needs and your preference. If the instructions aren't available for safe assembly, you should contact the manufacturer and request a copy.
The velcro straps on the mat fit into the plastic brackets or around the tubes. This allows the option of having a play mat for tummy time or a tunnel for the crawler. The accessories attach to the tube wherever you prefer. Eventually, baby will detach the hanging do-dads and perhaps reattach them in various locations.
This is a great play item for a baby, but NEVER leave the baby unsupervised while using this toy.
Jun 22, 2010 | Fisher Price Ocean Wonders Kick and Crawl...
Where is the throttle on a 95 ford econoline. Someone said it is on the accelarator?
start with your right foot.the accelerator pedal,attached to the throttle cable.attached to the throttle body attached to a butterfly valve inside the throttle body(of a carburettor)it is a tube of say 2"slimming down to 1.1/2" widening to 2"with the thinest part housing a fuel jet,and it is this tunnel effect that causes a rapid flow of air that mixes fuel in the inlet manifold.attached to the cylinder head etcetera
any help?
May 08, 2010 | 1995 Ford Econoline
I bought a 2000 caravan a few months ago, every time it rains water pours in from under the glove compartment on the passenger's side. I can reach my hand up into a tunnel like opening under that area. I...
sounds like the drain tube has fallen off check the side of the foot well is there a tube there that you could attach to the fire wall if so attach it this should solve your problem
Oct 09, 2009 | 2000 Dodge Grand Caravan
I want to clean my boxer AT air filter at home, but I couldn't find any air filter oil in my town, please tell me what is the most suitable common oil type for solve my matter?and also I want to know after...
biddy just rinse the filter in petrol then in hot soapy water with some bleach then let it dry off and dunk it in some air filter oil in a clean bowl and ring it in air filter oil once all covered squeze the access oil out and tip back in can its very easy just buy the oil off ebay done buddy
Sep 24, 2009 | 2005 Bajaj CT 100
I have an infocus in26 projector that has a shadow on one side of the image. i have been told this is indicative of a light tunnel collapse, is this a problem i can repair and if so how do i get the new...
it is the light tunnel. it is moderately easy to replace. just remember which screws go where. remove the lamp door, the top, rear and sides (8 screws on bottom, 2 in back). you'll see the colorwheel between the lamphousing and the lens. unplug the 2 cables for the colorwheel from the main board. unscrew the colorwheel base. the tunnel is under the metal clip next to the colorwheel. remove the clip and tunnel. replace tunnel and replace the clip, colorwheel, top, and lamp door. the top comes off as one piece, but must be replaced as 2 pieces. there are clips attaching the front to the top.
the part number for the tunnel is 306-0113-xx (if you have a in26+, it's # 306-0122-xx) and you can purchase it from any authorized infocus service center (find the closest one to you on the infocus website).
Aug 27, 2009 | InFocus IN26 Multimedia Projector
I need to install a kenwood cd player into my 2001 ford explorer step by step
goto the auto parts store and purchase a pair of stereo keys, fascia adaptor and wiring harness (you may need to get fascia and harness from a car audio store or circuit city.)
Then use the stereo keys to remove the factory stereo. Push them into the small holes on the front of the stereo push them slightly outwards and pull to release the stereo. Unplug all the connectors from back keeping track of where they fall.
Insert wiring harness into the stock wiring
attach fascia in regards to its packaged instructions.
Place cage from new stereo into the hole in the dash using the tabs on cage to secure it,
Attach stereo to other end of new harness along with aerial (may need adaptor for this also depending on the new head unit.)
Insert stereo into new cage and voila nice new stereo.
Nov 27, 2008 | Kenwood Car Audio & Video
Biddie Buddies Pink Small Animal Hideaway Tunnel Cage Attachment Tube for Hamsters Mice & Gerbils Logo
80 people viewed this question
Top Biddie Buddies Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Biddie Buddies Pets - Other Expert? Answer questions, earn points and help others
