Question about Refrigerators
How to thaw a 20 lb turkery in refigeratores - Refrigerators
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
Would need to know a bit more information.
1 Type of refrigerator (top freezer or side by side or bottom freezer)
2 How soon do you need turkey thawed
On 1
Top freezer type = place turkey on lowest shelve in a pan to catch water.
On Side by Side type = this will take the longest to thaw as it has a consistent temp through out.
On bottom freezer type - place turkey on highest shelf of refrigerator.
Posted on Nov 21, 2013
We bought a 22lb turkey but I think we only have an XL fryer. The turkey almost fits but it is still frozen. Can we cook it in the XL fryer if it fits when it thaws.
Probably yes. It will more flexible and elongated when thawed and it likely will be smaller when you pull the neck and giblets from the body cavity allowing the ribcage room to collapse.
Nov 22, 2014 | Grilling
SCOTSMAN ICEMAKER ICE SLAB NOT DROPPING DOWN TOO GRID
WHEN WAS THE LAST TIME THE EVAPORATOR WAS DESCALED? WHEN IT GOES INTO HARVSET DOES THE EVAP PLATE THAW OUT OR STAYS FROZEN?
Jan 05, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
How to defrost a frozen turkey
The evening of the 21st of December, it needs 3 days to thaw in a refrigerator.
Dec 20, 2013 | Refrigerators
Thaw a 22 lb frozen turkey in three days
Unless you live in a tent in Alaska a bird that size should pretty well thaw out in 3 days if left in a warmish invironment. Try a warm oven, lowest temp possible if still unfrozen after 3 days.
Nov 27, 2013 | Refrigerators
What are the torque settings for the head bolts on a 1999 ford taurus 3.0L.
This is the factory torque adjustment procedure for a 3.0L, also i post you the bolts tightening sequence. i hope that this could help you
  1. Tighten in five steps (refer to illustration in Cylinder Head Installation for tightening sequence):
    • Tighten in sequence to 47-53 Nm (35-39 Lb-Ft)
    • Then back off all bolts 360 degrees
    • Tighten in sequence to 27-33 Nm (20-24 Lb-Ft)
    • Rotate 85-95 degrees
    • Rotate an additional 85-95 degrees.
  2. Tighten in two steps:
    • 20-30 Nm (15-22 Lb-Ft)
    • 26-32 Nm (20-23 Lb-Ft)
  3. Advance 3/4 to 1 turn after gasket contacts sealing surface or tighten to 13-15 Nm (10-11 Lb-Ft).
  4. Tighten in two steps:
    • 7-15 Nm (6-11 Lb-Ft)
    • 26-38 Nm (20-28 Lb-Ft)
  5. Refer to illustration in the Cylinder Head Installation procedure for tightening sequence.
Mar 20, 2011 | Ford Taurus Cars & Trucks
No problem. Just how long will it take to roast a 16 lb turkey?
Is it frozen or thawed? The NuWave oven takes 12 minutes per pound thawed
Nov 26, 2010 | Vacuums
What size propane tank do i need with a Mr. Heater 45,000?
Rule of thumb is that you have 100,000 btu's per gallon of propane. This only translates into the length of time you have available in a tank of gas. The problem arises when you consume too much too fast. The gas can't produce enough vapor to continuously run and becomes dormant which is commonly known as "freezing up". You can use a typical (20 lb.)5 gallon propane tank (barbacue size), but it will more than likely freeze up in 2 - 3 hours of continous use. I'd suggest going to the next larger size a 30 lb. or 7.5 gallon size. The best way to work this system is to have two 5 gal. tanks so you can switch one out when it freezes and let it thaw while your using the spare.
Oct 04, 2010 | Mr. Heater Natural Gas Garage Heater -...
What is the heaviest weight paper I can feed through my Office Pro 7680?
Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
Plain paper, 20 to 24 lb (75 to 90 gsm)
Legal size paper, 20 to 24 lb (75 to 90 gsm)
Card stock, up to a maximum of 110 lb (200 gsm)
Envelopes, 20 to 24 lb (75 to 90 gsm)
Photo paper, 145 lb (236 gsm)
Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
Aug 09, 2009 | Office Equipment & Supplies
Paper thickness allowed
Type Paper weight Input tray capacity Plain paper 70 to 90 gsm (20 to 24 lb) 100 Cards 200 gsm (110 lb) 20 Envelopes 75 to 90 gsm (20 to 24 lb) 10 Transparency film N/A 20 Labels N/A 20 10 x 15 cm (4 x 6 inches) Photo 236 gsm (145 lb) 20
Dec 27, 2008 | HP PSC 1315 All-In-One InkJet Printer
Refrigerators Logo
184 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
