Question about Refrigerators
How to defrost a turker in refrigerators how long 20 lb
I let it set out for 24
Posted on Nov 21, 2013
How do you manually defrost a Samsung RF261 refrigerator and how long should the defrost cycle last.
Defrost cycles in normal conditions can last from five (5) to 25 (25) minutes, depending on variables like humidity, runs times and how often the door is opened. Defrosting the unit manually as you've done is merely a short term solution as it recurs again over time. You should find out why it is not working automatically, as intended. This could be a problem with poor air flow (fan, blower or restricted air), a bad control, or even loose connections. Forcing defrost without correcting the underlying issue will not eliminate the problem.
Dec 06, 2014 | Samsung Refrigerators
Pss26msta - freezer will not cool below 19 - 20. Refrigerator will not cool below 42 - 46. any suggestions on where to start?
The defrost circuit and the evaporator fan motor. The defrost circuit includes the main circuit board, the defrost heater, and the defrost heater safety.
Oct 07, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
How to defrost a frozen turkey
The evening of the 21st of December, it needs 3 days to thaw in a refrigerator.
Dec 20, 2013 | Refrigerators
How to defrost
Set on counter and wait 5 hours.
Nov 27, 2013 | Refrigerators
Cooking a defrosted turkey
Kept in the refrigerator it should keep for 2 or 3 days.
Nov 24, 2013 | Refrigerators
What are the torque settings for the head bolts on a 1999 ford taurus 3.0L.
This is the factory torque adjustment procedure for a 3.0L, also i post you the bolts tightening sequence. i hope that this could help you
  1. Tighten in five steps (refer to illustration in Cylinder Head Installation for tightening sequence):
    • Tighten in sequence to 47-53 Nm (35-39 Lb-Ft)
    • Then back off all bolts 360 degrees
    • Tighten in sequence to 27-33 Nm (20-24 Lb-Ft)
    • Rotate 85-95 degrees
    • Rotate an additional 85-95 degrees.
  2. Tighten in two steps:
    • 20-30 Nm (15-22 Lb-Ft)
    • 26-32 Nm (20-23 Lb-Ft)
  3. Advance 3/4 to 1 turn after gasket contacts sealing surface or tighten to 13-15 Nm (10-11 Lb-Ft).
  4. Tighten in two steps:
    • 7-15 Nm (6-11 Lb-Ft)
    • 26-38 Nm (20-28 Lb-Ft)
  5. Refer to illustration in the Cylinder Head Installation procedure for tightening sequence.
Mar 20, 2011 | Ford Taurus Cars & Trucks
I have a bad Paragon 8145-20 its Sunday all I have in stock is a Paragon 8045-20. I know voltage is the same. Will the 8045-20 work? What is the difference betweentime out and temperature out. If the...
See wiring diagrams and manuals at following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
8145-20 is 240V time initiated, pressure or temperature terminated with back-up time termination.
8045-20 is 240V time initiated, time terminated.
So 8145-20 has pressure or temperature limit switch that connects to terminal X that turns timer off, and ends defrost cycle. This timer is for hot gas defroster that has pressure/temperature limits. Check and see what the back-up time termination is set at on 8145-20. Look at small inner dial.
The 8045-20 timer does not use pressure/temperature limit switch, and instead you have to estimate length of time you want defrost cycle to run, and set inner dial to that time. Use same time as back-up time termination on 8145-20. Of course the pressure/temperature limits would not be exact and defrost cycle might not work correctly.
Here's the change-over wiring from 8145-20 to 8045-20.
There are other wiring variants depending on equipment.
240V hot wires from breaker box are L1 and L2
a) 8145-20 L1 is at terminal 1 > move L1 to terminal N on 8045-20
8145-20 L2 is at terminal N > move L2 to terminal X on 8045-20
b) 8145-20 hot gas defroster is at NO terminal 3 > move defroster to NO terminal 3 on 8045-20
Complete the 240 circuit to defroster by connecting to L2 at terminal X
c) 8145-20 refrigeration is at NC terminal 4 > move refrigeration to NC terminal 4 on 8045-20
Complete the 240 circuit to refrigeration by connecting to L2 at terminal X
Sep 12, 2010 | Paragon 8145-20 Defrost Timer
On a Paragon 8145-20 Defrost Timer, I know you land the refrigeration circuit on terminal 4, the heater on terminal 3, but what goes on terminal "X" and terminal "N"
Link below has 8145-20 wiring diagram:
Terminal N is 2nd wire needed to complete circuit.
In 240V 8145-20, there are two hot wires.
One Hot connects to terminal 1, with jumper to terminal 2.
Second Hot connects to terminal N, and this will power the clock motor and timer.
Terminal X is for temperature or pressure termination switch.
Defrost cycle works like this:
Timer is running but switched OFF.
Refrigeration fan is ON.
Timer switches ON, defrost cycle begins.
Refrigeration fan turns OFF.
Hot gas defrost turns ON.
When temperature-or-pressure limit switch reaches trip point, it switches timer OFF.
Refrigeration fan turns ON again.
Hot gas defrost turns OFF.
Aug 01, 2010 | Paragon 8145-20 Defrost Timer
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Paper thickness allowed
Type Paper weight Input tray capacity Plain paper 70 to 90 gsm (20 to 24 lb) 100 Cards 200 gsm (110 lb) 20 Envelopes 75 to 90 gsm (20 to 24 lb) 10 Transparency film N/A 20 Labels N/A 20 10 x 15 cm (4 x 6 inches) Photo 236 gsm (145 lb) 20
Dec 27, 2008 | HP PSC 1315 All-In-One InkJet Printer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
