Question about LG GH24LS50 Super Multi DVD±RW (±R DL) DVDRAM drive Serial ATA Burner
Where can I find the original drivers for GH24LS50
LG GH24LS50 HD-DT-ST DVD-RAM drivers
It's not a driver disk.... at least not for Windows OS's. Driver support comes from the OS not from a disk. The disk most likely only contains burning software, dvd decoding software, and possibly dos driver.
Jan 04, 2014 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
Lg super multi securdisc driver
Optical drives (at least all modern one's) do not require a driver when run in a Windows environment. The OS provides the support automatically. Is the drive shown/listed in My Computer?
Dec 25, 2013 | LG GH Computers & Internet
Drivers needed
available here http://www.driverscape.com/download/hl-dt-st-dvdram-gh24ls50-ata-device
LG GH24LS50 DVD-ROM Drive Plays Only CDs, Not DVDs...
Since you bought this used unit at a thrift store, it is entirely possible that it is defective.
Jul 24, 2017 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
Computer BIOS recognizes the SATA DVD Rewriter but Windows XP does not. The drive opens the loading door but it does not appear in the Windows XP explorer (My Computer).
Windows XP doesn't nativey support SATA. Check in BIOS to see if your motherboard supports sata to IDE emulation.
Comment back if you need further assistance.
Aug 17, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
He can support lightsribe? tank
According to the following features:
•SATA Interface
•MAX. 24x DVD±R Write Speed
•SecurDisc™ Technology
•RoHS Compliant
•CD-R/RW, DVD-R/RW/RAM/ +R/RW +/-R DL Read and Write Compatible
•Windows 7 Compatible
Product broucher Link
It does not support light scribe but the GH24LS50 models do.
Thank you for using FixYa.
Hopefull this information helps.
Jul 28, 2011 | LG GH24NS50 DVDRAM Burner
GH24LS50 doesn't recognize disk
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 16, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
When i try to copy files in writable disk folder it shows problem copying. . .when try to write disk using nero it shows burning failed.please help
hope this helps
Nov 30, 2010 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
LG GH24LS50 Super Multi  DVD±RW (±R DL)  DVDRAM drive  Serial ATA Burner Logo
64 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
