Question about GE Spacemaker JVM1640SJ Microwave Oven
Problem with GE Door Handle
I am trying to replace the handle on a GE Spacemaker Microwave Over. I have removed the top screw and removed the trim on the inside of the door. I can see the other screw that I need to remove, but I can't get it to move at all. This is where the handle broke. What am I doing wrong?
  • Spacehandle Apr 12, 2008
    I have been able to remove my handle quite easily. I don't know if it's because it was the bottom of the handle that broke off or not because it has been broken for quite a while. My problem now is to get a replacement handle and (2) screws. Can anyone tell me where I can get a new handle?
    GE Spacemaker M# J VM240BV 001 S# AM958276S
  • Anonymous Mar 23, 2014
    removing glass from the door of ge jvm154 over the counter microwave vn
  • GE Master
  • 9,149 Answers
You can find helpful exploded view diagrams and by entering your model number here: http://tinyurl.com/gv383
Posted on Oct 12, 2007
5 Suggested Answers
SOURCE: GE Spacemaker microwave model JVM130J - handle loose
Yes, you're right about the screws. The inner door is held by clips. Just pop it out using a butter knife or something similar. You might need to remove the door from hinges first (It's been too long after I repaired one of these, so I don't remember exactly).
Posted on Oct 14, 2009
MicrowaveSvc
  • 9149 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
MicrowaveSvc
  • 9149 Answers
SOURCE: GE profile mirowave JVM1350WW002. Handle broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Posted on Oct 11, 2009
MicrowaveSvc
  • 9149 Answers
SOURCE: my handle broke on me ge microwave spacemaker xl
The plastic door handle on our GE Spacemaker XL microwave oven (JVM1341WW 002) broke. I ordered and now have replacement handle and screws onhand. How do I gain access to inside of the door to replace...
I do not know your unit specifically but a lot of them you have to start by, slowly, from the inside of the door, lifting up on the choke that runs along the outer inside edge of the door. It looks like a plastic trim part about 3/4 of an inch wide. You slowly work around the whole door unit you get it popped out. a butter knife or steak knife works pretty well . I just use a small flat head screw driver The screws for the handle are behind that choke seal. Usually 2 Phillips head screws. The choke part just snaps in place and has no screws to put it back, just push back in place and you will hear it snap as you go. Be careful the plastic tabs are easy to break off
Aug 19, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
How do I repair the broken handle on my Spacemaker microwave from GE?
you have to remove the trim inside the door. you have to carefully pry the inner trim and kind of twist it as you remove it so you don't break it.
if there is enough of the handle left where the screw goes in(I'm assuming that's where it broke) sometimes you can drill into it a little and put a longer screw on. otherwise you need to buy a new handle.
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Oct 14, 2009 | Microwave Ovens
Oct 10, 2009 | GE Profile Spacemaker Over-the-Range...
How to replace the door handle on Spacemaker built in Microwave
take a small flat edge and pop out the plastic trim on the inside of the door, you will have to pry a bit but it will pop out, be very ccareful as it will break quite easily,,,,, the back of the handle is now accessable
two screws
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace the handle of a ge jvm1340, the top screw is easy, but the bottom screw seems unaccessible, can you help thanks, JG
There is a piece of trim on the inside of the door.
This trim is rectangular, about 1/2" wide, and goes around the outside of the glass. the trim has rounded corners. Take a knife and gently insert at a rounded corner, prying the trim out. Once you can put a finger behind the trim, you'll find it comes off easily, revealing the lower handle screw.
Jul 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Another broken handle
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 1800 Handle Base Replacement
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 06, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,331 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
