Question about Minolta Office Equipment & Supplies
Error COF33 in minolta di 1811
Incremente el atdc gain en minolta di1811 de 156 a 170. Press Utility-Stop-0-0-Stop-0-1 buscar Adjust in panel, next ATDC GAIN
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
This is an imaging unit error, the developer may need to be changed
Posted on Nov 21, 2013
3 Suggested Answers
  • 126 Answers
SOURCE: dark background print in minolta EP2050 mach.
Replace controller/ interface board. The next step would be the regulator board. If you must keep resetting the ATDC and receive different values ( assuming that the ATDC is new) then the problem is back. What supplies/ controls the ATDC? The controller, but forgive me if I am wrong, there is a small interface board after the controller that the ATDC is plugged into.
Posted on Jan 05, 2009
  • 990 Answers
SOURCE: minolta 2050 with ATDC set as 140 and current as 0%
Hello sir; replace auto toner sensor will be ok, that sensor is located on developer unit.
Posted on Jan 08, 2009
How to run f 8 bizhub 211
Follow the procedure below:
1. press the Utility
2. press the following keys [Stop] 0 0 [Stop] 0 1
3. choose 'Functions'
4. choose 'ATDC Auto Adjust'
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizup210 call service error cof32
If you want to remove this code by yourself then please perform these actions attentively. 1-Turn the machine ON.
2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
11-Restart the machine.
Jan 23, 2014 | Televison & Video
Konica Minolta di1611 indicating cof32
ATDC sensor malfunction.Enter in the service mode :
press the Utility key press STOP 0 0 Stop 0 1
select CLEAR DATA then select I/C counter and reset the counter press C.to exit press panel reset.
Feb 19, 2013 | Konica Minolta Office Equipment & Supplies
I have an error code C-2557 on this Biz 350 with the finisher, without the the finisher m/c works fine
C-2557 ATDC sensor malfunction.Enter in the service mode press following keys:
Utility-Metercount-Details-STOP-0-0-Stop-0-1-press 00000000 press Enter in Tech. mode select Printer than select ATDC gain and read the ATDC current value.If the value is situate 150-160 increase the value to 164-174 (to change the value press C and entering the new value)return in the copy mode turn OFF the copier open the rigy door than close and turn ON the copier and make a few copies.If the error persist discrease the ATDC value and make some copies.If the code persist change the developer .Before change the developer reset the special parts counter I/U counter,developer.After change the developer perform F8 and verify the new value to ATDC gain and notice.
Feb 19, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
My Dialta Di2011 gives me an error code cof32 service call. What are the likely problems?
COF 32 ATDC sensor failure.Enter in the service mode select Then.rep.mode select printer mode select ATDC gain adjustment note the current value then clear the current value and change the value up or down.Ex: the current value = 150 clear and change to 154 ,make a few copy and if the error code not displayed is OK.If the error code is appaire clear the value and enter 132,make a feww copy,if OK you are resolved a problem.
Service mode entering:
press utility key-press metercount-press details(if apaire the details windows)-press Stop 0 0 Stop 0 1 (if appaure admin code press 00000000 ) select techn.rep.mode-printer etc.
Feb 07, 2013 | Konica Minolta Office Equipment & Supplies
I am using a konica minolta bizhub 160 for a while, but now the machine is showing error 032 ni display pannel. please help me how remove it and what should i do.
Press this button in same order and sequence UTILITY-STOP-0-0-STOP-0-1
Where 0 mean zero of keypad then you see the msg "service mode" press down key and go to ADJUST and press OK press down key and go to ATDC and press OK check the value and increase some higher point again press OK press reset switch off and after some seconds switch on perform above actions until you get machine in ok condition or other otherwise you must be change the developer powder. but be sure to run atdc auto adjustment which is in SERVICE MODE-FUNCTION-ATDC AUTO ADJUST then press ok and leave the machine for complication his process,
Jan 27, 2011 | Office Equipment & Supplies
Minolta bizhub 162 error code 32
In Konica Minolta bizhub 210,162,211,163,182, error code "cof32" means "Automatic toner density control abnormality.
To remove this code or you want to get rid of this problem, simply call your technical service representative to solve this problem.
8-Press YES button.
Oct 04, 2010 | Konica Minolta bizhub C351 All-In-One...
I have the error C0F32 (Minolta - 210) on my display. I have to replace some parts ou just put some code?
Yes, you have to replace the parts which are necessary to be replace.If you do not want to replace the parts and also want to get rid of this problem then please perform these steps.....
1-Press utility button. 2-now press these buttons quickly stop, 0, 0 , stop, 0, 1. 3-You are now in service mode.here, scroll down and select ADJUST. 4-Now select ATDC gain. 5-Now increase the value shown on the display for example if the value is 145, increase the value to 165 or 170. To increase the value, press the C button to clear and now enter the new value by pressing the numeric keys on panel. After this press yes button and then press rest button.Re start the machine and start making copies..........
Aug 26, 2010 | Konica Minolta bizhub 180 All-In-One...
How to fix error c0f32 in konica minolta bizhub 180
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Mar 24, 2010 | Konica Minolta bizhub 180 All-In-One...
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
101 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
