Question about Iomega 250GB Ego Portable HD Red 250 GB Hard Drive
When I put a disk into my Iomega External USB POWERED Zip 250 Drive Z250USBPCMBP, it zips back and forth inside the drive and its icon won't appear on the desktop. I haven't been able to use it.
    Habit-Forming:
  • 135 Answers
Check in disk manage and device manager
Posted on Nov 21, 2013
PauldLucky
  • 268 Answers
SOURCE: external drive wont mount
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
Posted on May 14, 2008
  • 9 Answers
SOURCE: Iomega 250 GB external stopped working
This is really not a solution, but you should all try to connect your iomega to a imac, and use the Disk Utility (in Utilities folder), if you have any luck the hard drive will be recognized and you will be able to format it
Posted on Feb 14, 2009
trivialbrian
  • 8 Answers
SOURCE: Iomega 500GB data corrupted
The boot info is bad. If there is info that is needed you will have to use a recovery program like getdataback fat 32 and getdatabackntfs
Posted on Aug 02, 2009
danielizapat
  • 96 Answers
SOURCE: Iomega 500 gb external drive no longer mounts on mac os x tiger
ok I have had probs like this before. try plugging it in to different usb ports. also try another cable is it usb? or fire wire? I have had issues with several items doing the same thing I just try different cables and different ports and keep un plugging and plugging it back in. usually either a dif port os cable solves the issue. also try connecting it to another pc and see if u can access it. If you can access it from aonther pc that you have in your home or access to all the time I can tell u how to have it hooked to that pc but be able to access it from the origional pc that you had it hooked to.
Posted on Sep 24, 2009
Testimonial: "I will try some of these suggestions. I've already tried hooking it up to a PC at work (unrecognized completely) and a mac powerbook - won't mount."
Damilare
  • 358 Answers
SOURCE: dropped an Iomega 500gig external hard drive...
From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
That clicking sound that you are hearing from the Hard Drive is coming from the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Nov 23, 2009
Www iomega com
I believe you can use a PATA drive to USB adaptor. Hopefully you have the software for the Iomega drive, or perhaps that is available from Iomega. I've never tried it with an Iomega but have with numerous other drives. I hope this helps.
May 18, 2013 | Iomega ZIP 250 - Disk drive - ZIP ( 250 MB...
How do you get a disk to pop out of a iomega zip 100
Hello.
If your iomega drive is connected to your computer, open My Computer and right-click on the Zip disk drive icon and choose the option to eject.
If unsuccessful, or the drive is not connected to your computer, remove the disk manually. Look for a small hole or lever. If a small hole, use a straightened paper clip and push into the hole to remove the disk. If a lever, lift and pull backwards.
Hope this helps.
Jan 07, 2012 | Iomega ZIP 100 MB USB (32133) External ZIP...
Computer does not recognize usb device - 250 Zip drive Can you help? macdjean@charter.net
Does it recognize other peripherals plugged in? If the usb port is good you have need of drivers for your Zip drive. Or the bad news is, the zip is bad.
Jul 30, 2009 | Iomega ZIP 250 Internal ZIP Drive
I had a computer with a slot for reading iomega ZIP 100 disc. My new computer does not have this. Is there a device to read my zip dizc and send the contents to a USB port?
IOMEGA make a USB ZIP drive that reads and writes 100 and 250 Mb disks. Don't know if this is available any more, you might be able to pick one up 2nd hand.
If you still have your old computer, try networking your old and new computer together so you can transfer data from the ZIP drive on your old computer to your new one.
Mar 21, 2009 | Iomega Zip 100MB (31714) External ZIP...
100mb zip disk not reading
These are pre-formatted and servoed at the factory.
Awhile back I was researching the 'Click of death" fault and found a guy in Belgium or Germany that coded a repair program for bad disks. Googlee for it
sometimes when it formats, it hoses the servo information (which the drive uses to keep track of things) and the disk becomes useless. This is why I stopped using ZIP disks and won't even buy a drive when I see them for 9.99 ;-)
Jan 16, 2009 | Iomega Zip 100MB (31714) External ZIP...
USB 250 zip drive not displayed
Hey, lost connection with you
Thanks,
Ekse
Oct 29, 2008 | Iomega ZIP 250 External ZIP Drive
Cant figure out how to use zip drive when i have added a pass to my zip dr 250
1. Insert a blank disk into the zip drive
2. Give this disk a password (it can be any password, as long as you
remember it)
3. Using the Ioega toolset, set the zip drive's sleep time to a large
value (such as 1 minute)
4. Wait a while until the drive "spins down". You will hear the drive
stop spinning.
5. Take a pin or a straighten paper clip and stick it into a hole in
the back of the Zip drive. This will manually eject the blank disk.
6. Insert the disk you want to access (the one you don't know the
password to)
7. now use the IoMega toolset to remove the password. When prompted
for the password use the password from step (2).
This is just a word of warning in case you store any important information like I used to on zip disks. Perhaps move to a more secure medium.
May 09, 2008 | Iomega Zip 100MB (31714) External ZIP...
Iomega zip port
First of all, make certain you are only using 100 MB disks in a 100 MB reader.
If the problem is more complex than that, I have several questions:
Can you read different disks?
what type of connection is the zip drive using with the computer? USB?
does the zip drive need an external power supply?
will the zip drive successfullly read disks when connected to a different computer?
does the zip drive appear under my computer at all? even as an empty drive?
what operating system are you using?
Mar 29, 2008 | Iomega Zip 100MB (31714) External ZIP...
250 zip drive
Throw it away. It is rubbish.
Apr 24, 2007 | Iomega ZIP 250 External ZIP Drive
Open Questions:
Iomega 250GB Ego Portable HD Red 250 GB Hard Drive Logo
60 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
