Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
Have a Miller Dynasty 300 that won't tig weld, displays HELP 12 code. Suggestions??
Tried to switch from stick to Tig welding and unit displays HELP 12 code. Tried resetting to factory settings but continues to display HELP 12 code.
  • 2,113 Answers
Some welders have a resistor that is obvious and accessible but to give an error code it is likely something else inside. You'll have to look at the circuit board for a component that is burned. If you are lucky you will find a fuse.
Posted on Nov 21, 2013
3 Suggested Answers
co7196
  • 3433 Answers
SOURCE: Miller Syncrowave 200 wont strike arc for TIG
proper polarity?
Posted on Nov 12, 2009
  • 691 Answers
SOURCE: hi there..i have a miller dynasty 300 dx with ser.no.kk330787.i have problem in tig welding.the hf spark works fine but the machine fails to start the welding current.after a few attempts it starts by
check earth cable and cleanliness of parent metal?
Posted on Apr 25, 2012
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
I am getting holes appearing when I stop welding. There is nothing wrong with the gas (pressure/post/preflow checked) as i have checked it all out. I have put a new torch on and a new regulator but it has...
Wow what a great machine. You have so many options that you should be able to control the ending arc. Yes, you should be able to adjust the intensity of the HF. Also if you use the Sequencer Control, you should be able to finish the weld in a slope manner. I am including the owners manual. Operation starts on page 38. Miller has a team of welding engineer that will be able to help you set up your machine. Wish I had one.
Oct 04, 2017 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
I have a help 12 code on my little dynasty machine, and no manual to tell me what it means, is this a major problem with my machine
On this page enter your serial number and you will be able to download your manual http://www.millerwelds.com/service/ownersmanuals.php In the Dynasty 350 manual I see no "Help 12", there is a 32 and 22. If the Help 12 is only displayed when you push a button, it is saying the combination you have selected is not valid.
Dec 22, 2010 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Fan is always running wether welding or not.
Have you turned it off and try blowing compressed air on the cooling fins?
Jan 19, 2010 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Oct 20, 2009 | Welding Tools
I have a miller dynasty inverter tig welder   It has a help code that comes on when I turn it on the code is p-2
From the user manual for a generic dynasty model welder:
2 Help 2 Display
Indicates an open in the thermal protection
circuitry located on the left side of the unit.
Contact a Factory Authorized Service
Agent if this display is shown.
So you could have anything from a broken or disconnected wire to a bad thermal switch.
You can get user manuals specific to your welder at www.millerwelds.com
Rank this answer please,
Carl
Nov 26, 2008 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
346 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
