Question about GE Washing Machines
Wcvh6600hgg bearing replacement
Bearings
3 Suggested Answers
  • 186 Answers
SOURCE: NEED TO REPLACE WHEEL HUB BEARING OR ONLY THE BEARING
Front Is pressed into hub & knuckle.Rear is a Hub/Bearing Assembly held in by 4 10mm bolts.Will need to pound out with hammer in rear after bolts come out,lots of rust holding them in.Front Knuckle has to come off,Then a large Snap ring,then press out the hub,then the wheel bearing.Hope this helps
Posted on May 19, 2009
KAComstock
  • 274 Answers
SOURCE: I replaced the front wheel
Hi there. If you had the bearings replaced and they axle nut wasnt tightened enough you could be hearing that. If your car is front wheel drive it may be the CV axles. The constant velocity axles that drive the front wheels have 6 or more bearings each and commonly will make noise if any of them are starting to go bad. A better way to tell if it is the front axles is to listen to he noise while turing corners. They may make grinding, rubbing or clanking sounds. Those sounds will be even more prevelent if you accelerate while turning.
Posted on Apr 21, 2011
Is it possible to remove and replace front wheel bearings with out a press
In order to remove the front wheel bearings without press hub off the bearing and then the bearing out of the knuckle. To do the first step need a a Support Bridge.It is a special tool. Make bridge and use a general bearing pulled kit to replace bearings. use a "Front Wheel Drive Bearing Removal Adapters Puller Pulley Tool Set Kit" .To replace the bearing, remove front CV shaft taking care not to move the CV shaft too far out .
Nov 06, 2015 | 2002 Kia Rio
How to replace bearing on driveshaft of a 1992 isuzu rodeo
to replace the bearing you must seperate the axle from the rear differential. Then remove the rear section of the driveshaft and then the carrier bearing assembly. Replace the carrier bearing assembly then replace the driveshaft.
Nov 20, 2013 | Vehicle Parts & Accessories
I need to replace a ball bearing of a craftsman skill circular saw. Do I need a specialized replacement part (if so where can I find it.) or can I just use a generic ball bearing?
The bearing would be a standard bearing. There's plenty of engineering in bearings and consumer tool manufacturers don't waste their time designing application-specific bearings. It helps a lot if you can read the brand and number on the old bearing. It will also help if you can precisely measure the bearing. There are several bearing distributors on-line that can find the exact same thing or cross- reference for you.
May 20, 2011 | Craftsman Saws
How do you change the rear wheel bearings on a 2004 chevy express 1500 van?
Axle Shaft Bearing & Seal Removal & Installation To Remove:
  1. Raise and safely support the vehicle.
  2. Remove the axle shaft.
  3. If replacing only the seal, remove the seal using a suitable seal removal tool.
  4. If replacing the seal and bearing on the 8.6 inch axle, install the slide hammer and adapter behind the bearing and pull out the bearing and seal together.
  5. If replacing the rear axle shaft seal and the bearing on the 9.75 inch axle, install the J 29712 or equivalent bearing puller into the axle housing behind the axle bearing.
  6. Remove the axle shaft seal and the bearing by tightening the nut on the J 29712 bearing puller.
Use a slide hammer, bearing puller and adapter to remove the old axle bearing 88457g81.gif
To Install:
  1. Install the axle shaft bearing using a suitable size driver. Drive the bearing into the housing until the tool bottoms against the tube.
  2. Lubricate the seal lip and install the seal with a suitable seal driver. Make sure the seal is fully seated in the axle tube.
  3. Install the axle shaft.
  4. Fill the rear axle with the correct lubricant.
  5. Lower the vehicle.
Oct 18, 2010 | 2004 Chevrolet Express
I think the bearing on front of motor is going . Can it be replaced or does whole motor need replacing . Unit is cooling very well but making some noise and shaft of motor getting hot. Unit is Coleman...
the bearings are replaceable on some motors.. its a bit of work and you might first check the cost of a replacement motor .. it might be low enough to offset the amount of labor required to replace the bearing .. around here we have a hardware store that has a stock of most common replacement bearings ... some motors have welded bearing cages or bent metal captures .. those are harder to deal with. a way to make at least temporary repairs of such bearings involves punching the bearing to expand it , then re-drilling the bore to the correct size .. you might be able to force grease in the bearing for now to give you a little more time .. as it is it will eventually damage the motor shaft such that bearing replacement will not be reasonable ..
Aug 15, 2010 | Coleman Mach III Air Conditioner
2wd front wheel need to replace bearings or hub assembly which is best
A Front Wheel Drive Vehicle Can Have Two Types Of Rear Wheel Bearings: Serviceable Bearings, Or Nonserviceable, Sealed Bearings. When Sealed Bearings Fail, The Bolts Holding The Bearing And Hub To The Axel Or Control Arm Must Be Removed. When Installing The New Bearing Assembly, Torque The Bolts To Specifications.Some Manufacturers require The Use Of New Fasteners When Rear Bearings And Hubs Are Replaced.
When A Serviceable Wheel Bearing Is Used, The Bearing Can Be Disassembled And Packed With Grease.It Is Serviced Like A Front Wheel Bearing On A Rear-wheel-Drive-Car.
Apr 09, 2010 | 2003 Ford Explorer Sport Trac
Is there a reason for the bearings in a front loading machine to keep needing to be replaced
It could be that the new bearings are being fitted onto a worn drum shaft, this would soon cause the bearings to fail again.
If it has not been replaced, then it should be done so.
Jan 27, 2010 | Washing Machines
Pinion Bearing
the only way to replace pinion bearings is to remove the differential. you shouldnt have to remove the bearing to replace the seal
Nov 17, 2008 | 2004 Dodge Ram 1500
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Mar 20, 2008 | Maytag Neptune Washer
Washing Machines Logo
52 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
