How do you open a bose subwoofer - Audio Players & Recorders
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
If your talking about the subwoofer module, you need to remove the woofer. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 21, 2013
Bose 901 cd tray not opening
Not sure your model number is right. Bose 901 are speakers. Here is a video to show how a Bose CD tray was repaired. It might help.
https://www.youtube.com/watch?v=fFCCYCSwBPU
Mar 16, 2015 | Bose Audio Players & Recorders
How do I replace a speaker on my Bose Acoustimass 10 subwoofer?
The speaker probably needs not be replaced, only reconed or reconditioned. I would look into simplyspeakers.com or similar to get it done and then do the remounting yourself.
Nov 15, 2014 | Bose Audio Players & Recorders
How to wire Bose sub-woofer to Yamaha receiver
You did not mention the model of Bose subwoofer or Yamaha amplifier.However,depending on the speaker output,most amplifier works seamless with every non-powered Bose subwoofer.
Jan 28, 2014 | Bose Audio Players & Recorders
Bose 3-2-1 system subwoofer connect to denon avr
The subwoofer is not designed to be connected to a non-Bose amplifier.
Jun 07, 2012 | Bose Audio Players & Recorders
How to takwe apart a bose cinemate speaker
I wouldn't do it, because BOSE supposedly uses tubes to enhance the sound. Typically opening a speaker up creates scratches or breaks plastic parts.
Nov 17, 2011 | Audio Players & Recorders
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Mar 15, 2008 | Bose 901 VI Main / Stereo Speaker
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Sep 11, 2007 | Bose Acoustimass 10 III System
14 people viewed this question
 Grubhead
Grubhead
