Question about Xerox Documate Office Equipment & Supplies
3220 scanner doesn't turn off, can't be installed, stuck on "pp"
When turn on screen indicates "pp", that's all. I have to disconnect it to turn it off
Stuck at Motherboard splash screen
your stuck at the boot from DVD, you must boot form C to finish installation.
Jul 27, 2014 | EliteGroup P4M800-M7 Motherboard
3220 phone restriction
Phone restricted means your phone doesn't accept other sim card,it is locked in a particular provider.
How to unlock my phone? Here it is :
1. download this file and extract
http://www.uploadmb.com/dw.php?id=1306822616
2 open the application
3 choose your country and provider
3 enter your 15 digit imei located at the back of your phone or just type in *#06#
4 press calculate (a figure comes out with detail number from 1 to 7)
5 On your home screen mobile, enter the code given in screen.(
.preferably 1 & 7 is effective)
hope it helps...
Jun 11, 2011 | Nokia 3220
My all in one printer xerox workcenter 3220 gives me a mssege (Scanner Locked) do you have any answer please?
Scanner lock is located underneath the scan assembly, where the paper exits the printer. It may be stuck so slide it back and forth a couple of times.Unlock the scanner and then press 'Stop/Clear'.
Hope this helps.
Jan 22, 2011 | Office Equipment & Supplies
I need the "all for one" remote code for Insignia flat screen.
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Insignia TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I suggest using the search feature if Insignia is not listed in the code lists. Many manufacturers recycle other brands' codes.
I hope that helps.
Aug 12, 2009 | One For All URC-3021 Remote Control
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
Software for CX3200
The links on the page expire every 20 mins. here is what you need to do
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the ALL IN ONE heading select and then your scanner model.
3. Under the Drivers & Downloads section select Windows. Download the most current version of the Scanner Driver for your Windows operating system to your DESKTOP.
Reinstall
4. Complete the same steps for the printer model.
Scanner install
Make sure your USB is disconnected
1) Double Click on the Epson1****.exe file that you downloaded to your DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when prompted.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
Automated USB Driver Install
1) Before beginning, ensure the cable for the printer is disconnected and the printer is turned off.
2) Locate and double click on the downloaded driver installation file.
3) Click on OK at the first WinZip screen.
4) Click on UNZIP at the second WinZip screen.
5) Click on OK when WinZip is finished extracting files.
6) At the PRINTER UTILITY SETUP screen, click on OK.
7) The installer will now copy files to the computer. When this step is complete, it will tell you to attach the cable and power on the printer. Please connect the USB cable and turn on the printer.
8) The computer will install the new hardware.
9) Click on OK when the driver installation is completed.
Aug 11, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Ch error
Some of the covers of the machine might be open.
Regards,
Cäppärs
Jul 17, 2008 | Sharp AR-M160 Laser Printer
PowerPoint Viewer 2007
The PP2007 is just a converter from 2007 to 2003
If you are trying to view PP2003 files, then install the PP2003 viewer. The PP2007 is just a converter from 2007 to 2003
Jan 04, 2008 | Microsoft Office Outlook 2003 for PC
43 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
