Question about Kenmore 7.3 cu. ft. Steam Electric Dryer, Metallic Gray
Kenmore 7.3 cu ft
How to replace fuse and heating element
    Sergeant:
    Champion:
  • 310 Answers
Remove the back and the fuse is on the heater elemnt box
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Nov 21, 2013
My he2 dryer is not heating, what should I check first?
If it's electric, you have a bad heating element, probably need to be replace, it's the same as a hot water heater
Nov 15, 2014 | Kenmore 6.7 cu. ft. Electric Dryer
Kenmore repair manuals
remove heating element at the bottom and then using a Ohm meter (voltage tester on OHM setting) the reading should be less than 20 ohms between where the two wires were connected. If so replace the element
Oct 31, 2013 | Dryers
The thermal fuse dose what on a kenmore dryer110.67032
It Keeps your heating element from getting to hot, If it burns out the heating element won't come on.
Jan 25, 2013 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Dec 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My Whirlpool dryer has stopped heating-still seems like air flow and tumble is good. Recently replaced computer. Dryer is only 5yrs old.
if your heating element is good then you need to check the thermal fuses in the cabinet if one of those is bad then it needs to be replaced.all thermal fuse should have continuity as well as the element if one of them does not have any continuity then replace it
Mar 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
I have a Kenmore elite he3t washer. It flashes f5 at the beginning of a cycle
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Feb 04, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore elite dryer wont heat
heater element needs repair but usually replacement
Jul 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 7.3 cu. ft. Steam Electric Dryer, Metallic Gray Logo
55 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
