My Electrolux EWF 1074 wont spin I have voltage at the motor but no go
Machine wont spin. I removed the motor and cleaned the commutator and check the brushes all ok. Also meggared the motor which was fine. Put the machine on a spin cycle and water pump works but motor does not go. Little bit lost with no schematics as I am getting 110V AC on the motor
  • Washing Mach... Master
  • 17,129 Answers
If you have been able to check the motor with an external supply and found that it was working , then perhaps the control board has to be checked. Please test the motor, if it runs freely perhaps the drive is stuck , check the spindle assembly , could be jammed or the bearings could be faulty
Posted on Nov 21, 2013
  • Simon Leach Nov 21, 2013
    Thanks for that motor is ok found a diode, resistor and capacitor burnt out on the bottom right hand corner just waiting on parts to repair it now
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Posted on Feb 02, 2008
  • 38 Answers
SOURCE: hoover 500m spin cycle
That sounds like a broken motor couplin, slack drive belt, or worn bearings.
A repair person can determine which is it. I cant tell from here. However,
If you do this test you can eliminate one of the above. Lift the lid of the washer, hold the rim of the inner-tub and spin it clockwise and then anti-clockwise. If it spins both ways, you have a bad bearing which needs replacing.
Posted on Jun 01, 2008
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
SOURCE: beko wma 510 w washing
new pump washing machine will not spin or empty. what could be the problem
Posted on May 20, 2009
  • 4 Answers
SOURCE: Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Posted on Aug 19, 2009
How do i remove drain pump on electrolux ewf 1074
To access the drain pump, it is not necessary to remove the rear
cabinet shell. The pump can be accessed from the base.
a. Detach the clamps which secure the filter body to the base
and raise slightly.
b. Remove the drain pump.
c. Detach the drain hose.
d. Detach the wiring connectors.
Access to the pump is from the base of the appliance:
a. Remove the cover.
b. Detach the connectors.
c. Press down the anchor tab.
d. Turn the pump counter-clockwise.
e. Remove the pump.
When re-assembling:
• Insert the pump fully into its seat in the filter body before
rotating it.
• Check that the anchor tab is undamaged. If so, use a
3.5x19 mm screw to secure the pump.
Dado
Feb 27, 2017 | Electrolux Washing Machines
How do I replace the door handle on a electrolux front loader ewf 1074 washing machine
hi
you need to take the door apart to be able to replace the handle
is a easy job but remember the order you take it apart to be able to put it back on
Apr 23, 2015 | Electrolux Washing Machines
Why wont my ewf 1080 electrolux spin
Most likely the washing machine is stuck in Hold mode. Check if you have the spin speed knob at the correct setting.
Manual is available from here
http://www.manualslib.com/manual/616814/Electrolux-Ewf-1080.html#manual
Check the parts and schematics at this site
http://spares.bigwarehouse.com.au/index.php?cPath=64689_77309_77544&sort=2a&page=1
Aug 29, 2014 | Electrolux Washing Machines
Door locked
Try turning the main power off at the socket for 5 mins - the door may open then , if not turn the power back on and see what happens.
i had this problem on an Electrolux and it worked.
Jan 22, 2014 | Washing Machines
Heating element
Remove back plate and you should see it middle bottom of machine ,it has two Spade Terminals with two wire fitted to it also an Earth onto its case,You can look up heating elements on the net, this will give you some idea of what they look like and cost.
Jan 15, 2014 | Electrolux Washing Machines
Electrolux EWF 1074 - the white plug won't come
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 29, 2011 | Electrolux Washing Machines
A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Jul 24, 2010 | Electrolux Washing Machines
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
I have a ectrolux ewf 1074 with the padlock symbol
you need to turn machine on and hold the option and extra rinse buttons simultaneously for 6 seconds, the symbol will go and you'll be able to use your machine again as usual
Aug 02, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
