Question about KitchenAid KSM150PS Artisan Series Stand Mixer
The head shakes - KitchenAid KSM150PS Artisan Series Stand Mixer
  • KitchenAid Master
  • 1,225 Answers
Tip it upside down on a towel and tighten the screw in the middle of the screw hinge pin. Right up through the middle of the pedestal.
Posted on Nov 24, 2013
Top head shakes
Tilt it upside down on a towel and tighten the screw right up inside the pedestal that holds the hinge pin.
Nov 21, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid artisan mixer is loose and shaking
This could be the pivot rod between the head and the column being loose and out of place. Or it could be the hook activated by the lock lever not engaging properly. See the following Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Mar 30, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Nmixer starting only after shaking and sparking
It is possible that the motor is faulty and weak and the shake makes it contact to work . This is due to failure of the commutator or the brush and must be replaced. The spark is an indication of this fault as the brushes are weak to contact. Adjustment of the brush tension spring must help a bit but replacement is the best solution.
check the link below for tips:
http://www.espares.co.uk/advice/household-tips/a/12/1246/what-is-a-carbon-brush.html
Jul 23, 2011 | Food Mixers
The part of my KitchenAid mixer that hold the motor shakes violently when I use it. What can we try at home to fix this problem before going to repair shop? Thank you, Gillian Lukes
Hi, W/D here.
Try this:
1. Lift the mixer head, tilting it back.
2. Locate the large silver screw under the head, where it connects to the base. It will have a slot in it, for a standard slotted screwdriver.
3. Tighten the screw up.
Best regards, --W/D--
Please feel free to rate this solution. Thanks.
Feb 04, 2011 | KitchenAid 32685 Mixer
The head of the mixer is vibrating (shaking) a lot when mixing. It does this so much that I feel as though I need to hold onto it when it's mixing. If I turn it on without the bowl and just run the...
I am sure you are locking the tilt head in the down position when your using it right? If so then check to see if the beaters are hitting the bottom of the bowl. If they are then there is an adustment screw that sets the height of the head in the down position.
Jan 01, 2011 | KitchenAid Classic Stand Mixer
My mixer blades are bouncing against the bottom and sides of the bowl and making a racket. The head of the mixer bounces up and down when I'm mixing very liquid-y mixes. When I made bread, I noticed a...
The BUSH on the spindle is worn out. You will notice that liquid blending might make the liquid to flow out through this . If so it is confirmed. This is usual as the food particles gets caught on and wear off the bush in due time.
the blade unit has to be taken out and the bush must be changed after choosing the right bush for the steel spindle.
You can confirm rotating the spindle and see if this shakes.
Hope this tip confirms the fault.
Aug 21, 2010 | KitchenAid Food Mixers
I have a kitchen aid stand mixer and the head jiggles when it is on and the entire unit "hops" and shakes at high speed. what's going on and how do i fix it?
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Mar 08, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the beater to bowl adjustment quickly comes out of alignment, you may need to seek service. You may find a Kitchenaid certified service location locally at the following website:
http://caservice.kitchenaid.com/
Dec 14, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Oct 29, 2008 | Food Mixers
My mixer started to smoke!!
If it started to smoke out the back it may just be the motor brush.There are several parts available online I have included one site of many HERE
There are a lot of parts sites available you may want to find one close to you.You can check your brushes before you order replacement ones by unscrewing the large black screws on each side of the mixer if there is not much left of the metal portion on the end of the spring that's the problem.Hope this helps you.
Aug 17, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
44 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
