Question about Dryers
Control lock light is on,
Door wont open. how do I turn it off?
    Sergeant:
    Champion:
  • 310 Answers
Hit the breaker
Posted on Nov 21, 2013
Why door wont open
There can be many reasons but lets try the most common one first.
No elect power supply to the motor - check circuit breaker supplying elect power to the control box and or DC transformer. Check DC power supply for transformer to control box.
If that is ok adjust the up load turn switch - normally there are two adjusters regulating the open and close forces applied by the motor. If set to sensitive the door will open or close partially or even not at all. Quick check is open the door by releasing the manual lock and lifting the door by hand. Lock the manual lock again, press the door close switch/remote and see if it will close. If it closes the up switch is set to sensitive. Adjust by turning not more than a quarter turn before trying opening the door. If not sure to what side it must be turned turn it fully to the left try - if not working fully to the right and try again. It is however necessary to reduce the setting to a point just enough to open the door with any manual/hand assistance but where it should stop moving if light resistance is encountered such as hand pressure against direction of travel.
Check the remote contol batteries.
Check for some obstacle in the way of the door.
Check if the door is not locked.
Lastly check the micro switch settings on the door motor.
If the problem is not solved manufacturer assistance support.
Jul 19, 2014 | Building Materials
Bcm
Since the BCM must be checked for function with a special scan tool, and if defective replaced, then the new LCM module must be programmed to your vehicle. I think also the module in this year and model car is called the "LCM" or lighting control module. Same functions different name.
Mar 17, 2014 | 2007 Lincoln Town Car Signature Limited...
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Door open indicator light stays on , automatic door locks go on & off while driving and dome light and outside mirror lights wont go off after the car is turned off
i would hazard a guess and say that wires in the rubber boot from the door pilar to the door are damaged or the connection block in the door pillar in this the terminals are corroded or something similar
Nov 22, 2011 | 2002 Mercury Sable
The washing machine fills with water but then the door light comes on and the drum wont turn
Hello
The door light comes on when the washer control senses that the door is still open, please check the door lock assembly and the switch. You can also test it with a voltmeter and check how many volts its getting, you can also take a hair dryer and blow air on the door lock assembly so that if there is any dust this will blow it off. If the door lock/switch tests fine then check the wire going to the control. Please get back to me if you have any other questions.
Kevin
Nov 17, 2010 | Tricity Bendix AW1200 Front Load Washer
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Keyless entry not working
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Remove key. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press each remote control lock or unlock button twice. Ensure doors lock and unlock after each remote control operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
NOTE: A maximum of 3 remote controls can be programmed.
Mar 29, 2010 | 2004 Mazda 6
Control lock is on but door opens it finished the cycle but the control lock wont shut off can you help thanks
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Apr 13, 2008 | Whirlpool GHW9150 Front Load Washer
Dryers Logo
29 people viewed this question
Top Dryers Experts
